Motion blur algorithms
10 of 10 messages available
Motion blur algorithms Calculemus 13 Jul 19:09
  Motion blur algorithms Guillermo Espertino (Gez) 13 Jul 20:44
  Motion blur algorithms Alexandre Prokoudine 13 Jul 20:49
  Motion blur algorithms gg 13 Jul 21:01
   Motion blur algorithms Calculemus 13 Jul 21:31
    Motion blur algorithms Calculemus 13 Jul 21:36
     Motion blur algorithms Partha Bagchi 13 Jul 21:45
    Motion blur algorithms gfxuser 13 Jul 21:46
    Motion blur algorithms Jon Nordby 14 Jul 12:13
     Motion blur algorithms Calculemus 15 Jul 21:21
Calculemus
2012-07-13 19:09:25 UTC (over 13 years ago)
I need to implement motion blur(linear, radial and zoom )algorithms for an app I work on, like yours in GIMP.
In the .c file for motion blur it is not stated which source is used for the math/algorithm.
Someone knows the source, paper, book or whatever that was used as reference for implementing the motion blur algorithms?
Thanks
2012-07-13 20:44:13 UTC (over 13 years ago)
Hi
Is your application free software?
Please keep in mind that if you plan to publish your application and you re-use code from GIMP you have to honor the GPL V3 license, publishing the source code along the distributed binaries.
Releasing source code isn't a requirement if you don't plan to distribute the application to the public and keep it for yourself.
Kind regards, Gez.
2012-07-13 20:49:24 UTC (over 13 years ago)
Why do you necessarily want the algo from GIMP?
There are probably dozens of approaches. Finding a paper is not a problem :)
http://graphics.snu.ac.kr/publications/conference_proceedings/2007-dykim-egwnp.pdf + its references could be a start.
gg
2012-07-13 21:01:21 UTC (over 13 years ago)
Thanks
Motion blur is convolution of the image with a straight line ; defocus blur with a filled circle. Deblurring is done by the inverse operation, deconvolution.
This can be done as multiplication in the freq domain using FFT or convolution with a simple kernel image.
/gg
Calculemus
2012-07-13 21:31:03 UTC (over 13 years ago)
Nope I am far from releasing :)
Why GIMP? It is the only open source for this kinda thing I know.
Easy to find papers, hmm? Ok, I am a student and need your advice on this. Let's say I want to find a paper on an algorithm which I know what it does, and that is all. Where do I search? I am member at acm.org but usually they have very advanced papers.
Calculemus
2012-07-13 21:36:48 UTC (over 13 years ago)
Alexandre, but that paper is for motion blur for animation sequences. I just need motion blur for 2D images. It has two parameters, angle and displacement.
Partha Bagchi
2012-07-13 21:45:00 UTC (over 13 years ago)
gimp-developer-list@gnome.org
I would think Wikipedia would be perfect for a student to start their research? :)
I just typed "motion blur algorithm" within en.wikipedia.org and got hundreds of hits.
Hope that helps.
Partha
gfxuser
2012-07-13 21:46:56 UTC (over 13 years ago)
Hi Calcemus,
nearly every scientific paper starts with a survey on existing papers and research.
You could also look at Google scholar for survey or introduction papers. Another way is to use www.metager.de (a meta search engine) and select some scientific search engines there. This should give you some hints or serve as starting point into a particular topic.
Best regards,
grafxuser
Jon Nordby
2012-07-14 12:13:34 UTC (over 13 years ago)
May I ask why you are not simply using GEGL as the backend for you application? It implements a large number of image processing operations (every one you've asked about so far) and is designed to be reusable.
If there are issues which prevent you from using it we would love to hear about it so we can improve the situation.
Calculemus
2012-07-15 21:21:01 UTC (over 13 years ago)
So if I understand right, motion blur is just a convolution with a mask?
For linear motion blur you create a line and maybe smooth it a bit.
For zoom motion blur you need to calculate a different mask for each pixel. So you need a line drawing algorithm to create masks with lines rotated appropriately to face the center of the zoom.
Not sure about radial blur.
