help on images with higher precision
help on images with higher precision jmt 07 Jul 15:44
  help on images with higher precision Alexandre Prokoudine 07 Jul 21:18
jmt
2012-07-07 15:44:53 UTC (almost 13 years ago)
Dear list,
I have been using gimp for years, and the only feature I miss is the ability to handle high precision (more than 8bit per color) images, because most of my images are black and white : the trouble being with 8bit per color that feathering selections and modifying curves in selections creates step-like zones that are sometimes visible.
I tried the new 2.9 (from yesterday's git) ; unfortunately gimp crashes when : - opening an image ; then
- defining its precision to 16 bit ; then - selecting a zone (with the free select tool) ; then - feathering the selection (with a radius of 300) ; then - calling the curves tool crashes gimp.
I then tried to do the same sequence but staying on 8bit ; gimp crashes on the same step.
Should I revert to gimp2.8 ?
jmt
2012-07-07 21:18:35 UTC (almost 13 years ago)
You shouldn't be using 2.9 for production at this point of time for sure :)
Things break easily.
