Help :(
Help :( Caitlin Muela 01 Jul 16:55
  Help :( Alexandre Prokoudine 02 Jul 15:21
   Help :( Guillermo Espertino (Gez) 02 Jul 15:40
  Help :( Marco Ciampa 02 Jul 15:53
   Help :( SorinN 06 Jul 22:30
Caitlin Muela
2012-07-01 16:55:03 UTC (almost 13 years ago)
Help :(
Gimp Developer(s),
My friend is having some problems with Gimp. When she opens it, the Tool features that are usually located on the right (Layers, Paths, Undo, ect.) are missing. We’ve tried closing and opening Gimp, Looking at the Tool Bar at the top, and shutting down the computer, but nothing seems to work. The version she has is Gimp 2. I hope this was enough information needed to clarify the question. How can I help her get that Feature to show?
Sincerely, Cora
2012-07-02 15:21:07 UTC (almost 13 years ago)
Help :(
On Sun, Jul 1, 2012 at 8:55 PM, Caitlin Muela wrote:
Gimp Developer(s),
My friend is having some problems with Gimp. When she opens it, the Tool features that are usually located on the right (Layers, Paths, Undo, ect.) are missing. Weve tried closing and opening Gimp, Looking at the Tool Bar at the top, and shutting down the computer, but nothing seems to work. The version she has is Gimp 2. I hope this was enough information needed to clarify the question. How can I help her get that Feature to show?
"GIMP 2" is too generic. Is it GIMP 2.6 or GIMP 2.8?
The "Windows > Dockable Dialogs" submenu has all the floating dialogs you probably need.
gimp-developer-list@gnome.org
2012-07-02 15:40:03 UTC (almost 13 years ago)
Help :(
El 02/07/12 12:21, Alexandre Prokoudine escribi:
Gimp Developer(s),
The "Windows> Dockable Dialogs" submenu has all the floating dialogs you probably need.
And if she's using GIMP 2.8 with the single window mode on, probably it's a good idea to temporarily disable it (under the "windows" menu), move the toolbar to the left, re-open the closed dockable and when everything is in place activate the single window mode again.
Gez.
Marco Ciampa
2012-07-02 15:53:10 UTC (almost 13 years ago)
Help :(
On Sun, Jul 01, 2012 at 11:55:03AM -0500, Caitlin Muela wrote:
Gimp Developer(s),
Try to press the "Tab" key and see what happens...
SorinN
2012-07-06 22:30:39 UTC (almost 13 years ago)
Help :(
..or press "Control + B" and the Toolbox will come ..press Tab and the right floating boxes will come
OR
you can add manually those boxes to life by using Windows >> Dockable Dialogs ..and then choose the toolbox you need in few steps you can bring back all missing boxes
2012/7/2 Marco Ciampa :
Gimp Developer(s),
Marco Ciampa
+--------------------+ | Linux User #78271 |
| FSFE fellow #364 |
