Can't get a stable build
Can't get a stable build Roman Joost 24 Jun 02:32
  Can't get a stable build Ulf-D. Ehlert 24 Jun 11:45
Roman Joost
2012-06-24 02:32:35 UTC (over 13 years ago)
I've spend now quite some time on this and can't really reproduce what's wrong, because it seems to happen quite arbitrary. What I get is:
[PO] po/ko/using.po po/ko/using.po:2339: `msgid' and `msgstr' entries do not both begin with '\n' po/ko/using.po:2442: `msgid' and `msgstr' entries do not both begin with '\n' po/ko/using.po:3278: `msgid' and `msgstr' entries do not both begin with '\n' /usr/bin/msgfmt: found 3 fatal errors 449 translated messages, 311 fuzzy translations, 314 untranslated messages.
make: *** [po/ko/using.po] Error 70 make: *** Deleting file `po/ko/using.po'
If I ran the build again, this error comes up with a po file in a different language. I wonder if it is a version problem of automake, i18ntools (e.g. msgfmt) or perhaps our customized version of xml2po.
The whole log can be found here:
http://build.node.mooball.net:8080/job/gimp-help/142/console
in case that helps.
Any pointers appreciated.
Cheers,
Roman Joost
www: http://www.romanofski.de
email: romanofski@gimp.org
Ulf-D. Ehlert
2012-06-24 11:45:10 UTC (over 13 years ago)
Usually those strange error messages *really* mean that a po file is broken and messes up everything...
Some fuzzy message strings make trouble.
msgformat worked for me when I called it without the "--use-fuzzy" option:
msgfmt --check --statistics -o /dev/null po/ko/using.po
so you could try e.g.
make ... MSGFMTFLAGS="--check --statistics"
Maybe we should simply remove this option?
However, with "--use-fuzzy" msgfmt reports line 1335, ...
#: src/using/script-fu-tutorial.xml:446(programlisting) #, fuzzy, no-wrap
msgid ""
"\n"
"(let*\n"
" (\n"
" (x\n"
" '(\"GIMP\" (1 2 3) (\"is\" (\"great\" () ) ) )\n" " )\n"
" )\n"
" x\n"
")\n"
msgstr "김프 사용자 설명서가 없습니다."
... line 1415, ...
#: src/using/script-fu-tutorial.xml:512(programlisting) #, fuzzy, no-wrap
msgid ""
"\n"
" (let* (\n"
" (a 1)\n"
" (b 2)\n"
" (c 3)\n"
" )\n"
"\n"
" (list 5 4 3 a b c)\n" " )\n"
msgstr "언어 목록"
... and line 2040:
#: src/using/script-fu-tutorial.xml:1203(programlisting) #, fuzzy, no-wrap
msgid ""
"\n"
" (gimp-display-new theImage)\n" " "
msgstr "새 인스턴스로 김프를 시작합니다."
Hmm, meanwhile I'm quite sure that we should remove thet option...
Ulf
