Exported options via PDB, and a possible bug.
Exported options via PDB, and a possible bug. Chris Mohler 21 Jun 00:13
Chris Mohler
2012-06-21 00:13:44 UTC (over 13 years ago)
I'm attempting to access the image's export options via PDB or python, but can't seem to locate them.
For example in 2.8: 1. Export, JPEG, Choose quality of '85'. 2. Next 'Export' saves quality of '85'
Is there any way from the PDB/console to access either: - the second 'Export' function?
- or the saved option '85' for quality?
Now, on to the possible bug ;)
Test file: JPEG with quality setting of 88.
In 2.6.11: File->Open JPEG
File->Save As JPEG
Options dialog presents quality slider at previous setting of 88
In 2.8.0 File->Open JPEG
File->Export JPEG
Options dialog presents quality slider at default setting of 90
I'm pretty sure there was a bug in the 2.8.0 release that prevented loading/saving the default export options, but it appear this behavior is something else. I'm compiling master now but can anyone confirm?
Thanks, Chris
