GIMP mouse and key quickreference
GIMP mouse and key quickreference Ulf-D. Ehlert 12 Jun 16:32
  GIMP mouse and key quickreference Roman Joost 13 Jun 10:49
   GIMP mouse and key quickreference Ulf-D. Ehlert 14 Jun 19:09
    GIMP mouse and key quickreference Kolbjørn Stuestøl 14 Jun 21:22
     GIMP mouse and key quickreference Marco Ciampa 14 Jun 23:04
Ulf-D. Ehlert
2012-06-12 16:32:20 UTC (almost 13 years ago)
On Mon, Jun 11, 2012 at 05:17:33PM +0200, Marco Ciampa wrote:
I just noted that the mouse and key quickreference PDF files are not updated. A quick investigation has reveald that the .pot file is not updated. How to update the .pot file?
1) please update the .pot file and describe how to do it ... 2) ... possibly via make update-pot
3) update Makefile.in to incorporate make update-po-xx or something similar to automate update handling
TIA
PS: I am not an expert of automake and autoconf but if someone (Ulf?) is able to do it, would you please describe how you have done it? I can learn something from it and perhaps, contribute next time...
It looks like there is simply no rule to create the pot file, and also no rule to update po files. I guess that Roman updates these files manually (on demand?).
IMHO adding two new rules
po/gimp-keys.pot: gimp-keys.xml create/update pot-file
po/%.po: po/gimp-keys.pot: create/update po-file
shouldn't break anything - or do I miss something?
Ulf
Die Heiligenlegenden entlarvte Luther als Mrchen. An den Bibellegenden
hielt er fest; am Teufelsglauben auch; am Hexenwahn auch; an der
Ketzervertilgung auch; am Antisemitismus auch; am Kriegsdienst, an der
Leibeigenschaft, den Frsten. Man nennt es: Reformation.
		-- Karlheinz Deschner
gimp-docs-list mailing list
gimp-docs-list@gnome.org
Roman Joost
2012-06-13 10:49:27 UTC (almost 13 years ago)
Actually, I've never spend time on checking if the pot is updated.
Yeh - that should do the trick. Thank you!
I currently run a simple make svg in the quickreference and convert them to PDF with rsvg-convert. Not to mention that the styling could need some work, as some quickrefences show displayed entries.
Cheers,
Roman Joost
www: http://www.romanofski.de
email: romanofski@gimp.org
Ulf-D. Ehlert
2012-06-14 19:09:16 UTC (almost 13 years ago)
I have pushed my changes. After
./autogen.sh ... or
automake # this should update quickreference/Makefile.in ./configure ... # this should update quickreference/Makefile
you should be able to update pot and po files in quickreference with
(cd quickreference && make pot)
and/or
(cd quickreference && make po-LANG # 'make po' for all languages)
It may be necessary to touch quickreference/gimp-keys.xml.
Ulf
Frage an Schiller: kann das Gesetz der Freund des
Schwachen sein, wenn es die Mchtigen machen?
Kolbjørn Stuestøl
2012-06-14 21:22:47 UTC (almost 13 years ago)
Den 14.06.2012 21:09, skreiv Ulf-D. Ehlert:
./autogen.sh ... or
(cd quickreference&& make pot)
Tried, but resulted in "Nothing to be done for 'pot' " (I have no pot file in this folder.)
and/or
(cd quickreference&& make po-LANG # 'make po' for all languages)
and thereafter "make po-nn" result: "po-nn is up to date".
Yes. Hurray.
$ touch gimp-key.xml $ make pot
Making po/gimp-keys.pot
Well done Ulf.
Kolbjoern
Ulf
Marco Ciampa
2012-06-14 23:04:25 UTC (almost 13 years ago)
On Thu, Jun 14, 2012 at 11:22:47PM +0200, Kolbjrn Stuestl wrote:
Well done Ulf.
Many, many thanks Ulf.
Marco Ciampa
| Linux User  #78271 |
| FSFE fellow   #364 |
