LibreJS and Gimp.org
This discussion is connected to the gimp-web-list.gnome.org mailing list which is provided by the GIMP developers and not related to gimpusers.com.
10 of 10 messages available
LibreJS and Gimp.org Jackson 02 Jun 14:06
  LibreJS and Gimp.org Michael Schumacher 02 Jun 14:32
   LibreJS and Gimp.org Niel 02 Jun 19:36
  LibreJS and Gimp.org Patrick Shanahan 02 Jun 18:33
   LibreJS and Gimp.org Loic J. Duros 02 Jun 20:57
   LibreJS and Gimp.org Loic J. Duros 05 Jun 02:11
    LibreJS and Gimp.org Loic J. Duros 05 Jun 02:13
   LibreJS and Gimp.org Loic J. Duros 02 Jun 20:54
LibreJS and Gimp.org Loic J. Duros 02 Jun 18:34
Jackson
2012-06-02 14:06:50 UTC (almost 13 years ago)
Gimp.org does not work with https://www.gnu.org/software/librejs/ Doesn't load.
2012-06-02 14:32:36 UTC (almost 13 years ago)
Does LibreJS provide anything that would help to identify the problem? Or is there some other thing we could use to check for problems?
Regards, Michael
Patrick Shanahan
2012-06-02 18:33:27 UTC (almost 13 years ago)
* Jackson [06-02-12 10:07]:
works for me.....
Loic J. Duros
2012-06-02 18:34:59 UTC (almost 13 years ago)
Hi:
I'm the maintainer of GNU LibreJS. Although this issue might be related to something on the gimp.org's page, it's the responsibility of LibreJS to properly load any page with or without JavaScript. I'll look into this and see if it is related to a bug in LibreJS.
Many thanks for reporting this issue,
Loic Duros
Niel
2012-06-02 19:36:04 UTC (almost 13 years ago)
Sorry Jackson, intended to reply to the list
This shows up in Firefox's error console:
Error: uncaught exception: [Exception... "Component returned failure code: 0x8050000e (NS_ERROR_ILLEGAL_INPUT) [nsIScriptableUnicodeConverter.ConvertToUnicode]" nsresult: "0x8050000e (NS_ERROR_ILLEGAL_INPUT)" location: "JS frame :: resource://jid1-ktlzuoiikvffew-at-jetpack/api-utils/lib/cuddlefish.js -> resource://jid1-ktlzuoiikvffew-at-jetpack/librejs/lib/html_script_finder/dom_handler/request.js :: :: line 88" data: no]
It looks to me that the immediate problem is with LibreJS. Until it loads the page without an exception the JS cannot be easily checked, i.e it would have to be done manually.
-- Niel Archer
niel.archer (at) blueyonder.co.uk
Niel
Sorry Michael, intended to reply to the list
http://www.gnu.org/software/librejs/free-your-javascript.html
The LibreJS add-on to IceCat, IceWeasel, and mozilla based browsers identifies blocked and passed JS.
-- Niel Archer
Loic J. Duros
2012-06-02 20:54:14 UTC (almost 13 years ago)
The issue is a new module of LibreJS which was developed so that it can be compatible with Https-Everywhere. Some of the JavaScript files in gimp.org are detected as latin-1, apparently. I'll work on fixing this issue.
Loic J. Duros
2012-06-02 20:57:38 UTC (almost 13 years ago)
To temporarily address this issue, you can either use LibreJS 4.6, which doesn't use the same request module, or add gimp.org to the whitelist from the about:addons preferences page.
Thanks,
Loic J. Duros
2012-06-05 02:11:53 UTC (almost 13 years ago)
Hello:
I wanted to mention on this list that I've updated LibreJS to fix the bug it had visiting gimp.org. You might want to try to install LibreJS version 4.7.1 and check if gimp.org is loading properly now.
You should see when clicking on the LibreJS widget (bottom right in addon bar) that the scripts are all blocked except for jQuery. It would be great for your visitors to release these scripts under a free license so that they can be detected by LibreJS properly: http://www.gnu.org/software/librejs/free-your-javascript.html
For more information on why it is important to make JavaScript code free, please read: http://www.gnu.org/philosophy/javascript-trap.html
Many thanks!
Loic Duros
Loic J. Duros
2012-06-05 02:13:31 UTC (almost 13 years ago)
I forgot to add the direct link to the add-on: http://ftp.gnu.org/gnu/librejs/librejs-4.7.1.xpi and to the project page: http://www.gnu.org/software/librejs/
Thanks!
