make distcheck
7 of 7 messages available
make distcheck Roman Joost 29 May 09:20
  make distcheck Ulf-D. Ehlert 29 May 11:33
   make distcheck Roman Joost 30 May 00:11
    make distcheck Ulf-D. Ehlert 31 May 11:08
     make distcheck Ulf-D. Ehlert 02 Jun 18:56
      make distcheck Roman Joost 03 Jun 08:46
       make distcheck Ulf-D. Ehlert 04 Jun 10:57
Roman Joost
2012-05-29 09:20:23 UTC (almost 13 years ago)
make distcheck
I'm currently looking a bit puzzled over an error message when running:
make distcheck
The build fails with an error message:
make: *** No rule to make target `stylesheets/plainhtml.xsl.in', needed by `distdir'. Stop.
http://build.node.mooball.net:8080/job/gimp-help-dist-check/4/console
Any ideas why? I checked already the Makefile and my guess is that it is simply not implemented?
Cheers,
Roman Joost
www: http://www.romanofski.de
email: romanofski@gimp.org
Ulf-D. Ehlert
2012-05-29 11:33:33 UTC (almost 13 years ago)
make distcheck
make distcheck
Our usual autotools problems...
I get
ERROR: files left in build directory after distclean: ./install-sh
./config.guess
./config.sub
./missing
make[1]: *** [distcleancheck] Fehler 1
distcleancheck seems to be the last test, so I assume that stylesheets/plainhtml.xsl.in didn't make any problems:
"config.status: creating stylesheets/plainhtml.xsl"
My tools:
configure: 2.8.0 autoconf: 2.68
automake: 1.11.1
HTH
Ulf
Wenn die Affen katholisch wrden und der Kirche ntzten,
ich bin sicher, sie sprchen einige heilig. - Aber haben
wir denn diesen Fall nicht schon?
		-- Karlheinz Deschner
gimp-docs-list mailing list
gimp-docs-list@gnome.org
Roman Joost
2012-05-30 00:11:15 UTC (almost 13 years ago)
make distcheck
make distcheck
I get
./config.guess
./config.sub
./missing
hmpf ... that is quite different.
My tools:
automake: 1.11.1
My tools:
autoconf: 2.68
automake: 1.11.1
confiugre: 2.8.0
Doesn't seem to be that different. I've created a package and checked it. It seem to be all fine. I would be nice to use the distcheck as a verification when doing releases.
Cheers,
Roman Joost
Ulf-D. Ehlert
2012-05-31 11:08:08 UTC (almost 13 years ago)
make distcheck
I get
./config.guess
./config.sub
./missing
Weird news:
================================================= gimp-help-2.8.0 archives ready for distribution: gimp-help-2.8.0.tar.gz
gimp-help-2.8.0.tar.bz2
The only difference is the ALL_LINGUAS variable - I reduced the number of languages to
a) "de en fr" failed (distcleancheck!) b) "de en fr it nn" passed!
c) "de en fr" passed!!
d) "de en fr" passed again
With ALL_LINGUAS set to all or nearly all languages:
e) (all) 'ca' failed f) (all but 'ca') 'en_GB' failed g) (all but 'ca', 'en_GB') tbd.
Does this help? ;-)
Ulf
Ich finde es nicht nur schner, sondern auch
ntzlicher, meinem Hund zu folgen als der Obrigkeit.
Ulf-D. Ehlert
2012-06-02 18:56:38 UTC (almost 13 years ago)
make distcheck
I added missing po files and fixed a small bug in quickreference/Makefile.am, now 'make distcheck' succeeds.
'make validate-xx' still failes for a few languages xx; I will check this later.
Ulf
Verdient eine Menschheit, die Trilliarden Tiere
ttet, nicht eben das, was sie dem Tier antut?
Roman Joost
2012-06-03 08:46:43 UTC (almost 13 years ago)
make distcheck
Hi Ulf,
Thank you so much for this.
I've created a 2.8.0 release and updated the web site.
Your changes seem to work well!
http://build.node.mooball.net:8080/job/gimp-help-other-formats/15/console
I can put this into Jenkins too if you want. That way we know if something is b0rked, or the distribution got a new set of autotools :)
Cheers,
Roman Joost
Ulf-D. Ehlert
2012-06-04 10:57:27 UTC (almost 13 years ago)
make distcheck
Ok, 'make-validate-LANG' should work now for every language, but...
...the released glossary files are probably completely useless for 'fi', 'hr', 'lt', 'nl', and 'pl'.
For future releases, I have replaced the glossary.po files with new, empty templates.
Sounds like a good idea to me. Should we add a 'validate-all' target to the Makefile to simplify usage?
Ulf
Wer beleidigt, braucht nicht unrecht haben; es gibt Kpfe, denen
man erst Verstand liefern mte, um sie berzeugen zu knnen.
