Ambiguous message when saving over VFS
Ambiguous message when saving over VFS jEsuSdA 8) 29 May 08:55
jEsuSdA 8)
2012-05-29 08:55:31 UTC (almost 13 years ago)
Hello!
I'm using Gimp 2.8 to edit some graphic files over ftp (VFS), but when saving a strange message appears:
Mensaje de GIMP Ha fallado el guardado de «ftp://XXXX/right_col_bottom_back.png» éxito
The translation will be some like that:
Gimp message Saving «ftp://XXXX/right_col_bottom_back.png» was failed. Success
The file was saved correctly, but the message says the opposite thing... and the same thing at same time. :D
¿Could be caused by permissions or it is a bug?
Thanks! Salu2 de jEsuSdA 8)
