[PATCH] Fix rect position when trasnforming to view coordinates
[PATCH] Fix rect position when trasnforming to view coordinates Jordi Fita 26 May 11:11
  [PATCH] Fix rect position when trasnforming to view coordinates Michael Muré 29 May 05:08
  [PATCH] Fix rect position when trasnforming to view coordinates Jon Nordby 19 Jun 08:27
Jordi Fita
2012-05-26 11:11:32 UTC (almost 13 years ago)
I sent attached to this letter a patch to view-helper's model_rect_to_view_rect() function that computes the position of view rectangle correctly--instead of subtracting the rectangle's coordinate from the scaled position, it subtracts the widget's position.
With this patch, gegl-gtk-paint works better.
Jordi
Michael Muré
2012-05-29 05:08:01 UTC (almost 13 years ago)
Please fill a bug and attach your patch to it. https://bugzilla.gnome.org/enter_bug.cgi?product=GEGL
Patch like this tend to get lost if nobody take care of them immediately.
Thank you.
2012/5/26 Jordi Fita
Jordi
_______________________________________________ gegl-developer-list mailing list
gegl-developer-list@gnome.org
https://mail.gnome.org/mailman/listinfo/gegl-developer-list
Jon Nordby
2012-06-19 08:27:53 UTC (almost 13 years ago)
I've now applied the patch, and also added some tests for redraws with scaling+translations.
Thanks a lot for your contribution!
commit f3bce7aecaf408168b24cb460983f5dca326cda0 Author: Jordi Fita
Date: Sun May 6 13:28:54 2012 +0200
Fixed rect pos in model_rect_to_view_rect
