application suggestions to evaluate tool options - input needed
application suggestions to evaluate tool options - input needed foser 24 May 19:08
foser
2012-05-24 19:08:45 UTC (almost 13 years ago)
as mentioned earlier a new UI design project has started under the supervision of Kate and Peter with a focus on the Tool Options. The current progress can be found on
http://gui.gimp.org/index.php/Work_in_progress .
For the next step we are looking to evaluate GIMP using the user scenarios mentioned in the link above, the scenarios are firmly rooted in the vision described. Besides evaluating GIMP we will also be looking at a number of (similar) applications and their use of Tool Options or equivalant UI elements.
Of course we have some applications in mind, but we would also like to hear from you what applications you think of if you think about working with tools and manipulating their options in a graphics manipulation context. Name the application and a short description of how it supports and/or interferes with your workflow.
We will use the suggestions here as a basis for the list of applications to be evaluated in this design process.
I'm eager to find out what you all come up with.
Thanks, foser
