executable flag
executable flag Kolbjørn Stuestøl 23 May 21:52
  executable flag Kolbjørn Stuestøl 24 May 00:37
   executable flag Vitaly Lomov 24 May 08:27
    executable flag Kolbjørn Stuestøl 24 May 09:31
Kolbjørn Stuestøl
2012-05-23 21:52:30 UTC (over 12 years ago)
executable flag
When doing "git commit" I get the error message "Translation files should not be executable. Please remove the flag and try to push again." And then some suggestions how to repair it. My question is: Where do I find this flag and what should it be set to? (By using a hex editor).
I am writing the po files using Notepad++ set to format UTF-8 without Byte Order Mark. My next step will be to try other formats, so perhaps my question is irrelevant? But I am curious about what happening.
BTW: The program tells me that an error has occurred, but the git log tells all is ok although the push stops with the mentioned error message. As far as I can see the log is wrong. But that's another question.
Kolbjoern
Kolbjørn Stuestøl
2012-05-24 00:37:49 UTC (over 12 years ago)
executable flag
Den 23.05.2012 23:52, skreiv Kolbjrn Stuestl:
Kolbjoern
According to the http://git.gnome.org/browse/gimp-help-2 the git log is right. The updates goes through but the program still tell me that the push failed. Ridicules.
Kolbjrn
_______________________________________________ gimp-docs-list mailing list
gimp-docs-list@gnome.org
Kolbjrn Stuestl, Stuestl, 4580 Lyngdal
Telefon: (47) 38 34 78 62,  (47) 917 81 125
Stuestl heimesider: http://www.stuestoel.no
Sj ogs
Lyngdal hagelag: http://www.stuestoel.no/hagelag/hagelag.php
Mandal og Lister pyntegrntlag: http://www.mlpynt.no
GIMP p norsk: http://www.gimp.no
Vitaly Lomov
2012-05-24 08:27:06 UTC (over 12 years ago)
executable flag
I got that error before. I think it's the way file is saved on Windows - it automatically acquires execution permissions if it's a new file and sometimes when existing file.
in Cygwin you just run
chmod 666 file_name
In git there is a way to check what the permissions were before and you can set them to original, as above, to avoid committing just the permission changes.
On Thu, May 24, 2012 at 1:37 AM, Kolbjørn Stuestøl wrote:
Den 23.05.2012 23:52, skreiv Kolbjørn Stuestøl:
BTW: The program tells me that an error has occurred, but the git log tells all is ok although the push stops with the mentioned error message. As far as I can see the log is wrong. But that's another question. Kolbjoern
According to the http://git.gnome.org/browse/**gimp-help-2the git log is right. The updates goes through but the program still tell me that the push failed. Ridicules.
Kolbjørn
______________________________**_________________ gimp-docs-list mailing list
https://mail.gnome.org/**mailman/listinfo/gimp-docs-**list
Kolbjørn Stuestøl, Stuestøl, 4580 Lyngdal Telefon: (47) 38 34 78 62, (47) 917 81 125 Stuestøl heimesider: http://www.stuestoel.no Sjå også
Lyngdal hagelag: http://www.stuestoel.no/**hagelag/hagelag.php Mandal og Lister pyntegrøntlag: http://www.mlpynt.no GIMP på norsk: http://www.gimp.no
Kolbjørn Stuestøl
2012-05-24 09:31:35 UTC (over 12 years ago)
executable flag
Den 24.05.2012 10:27, skreiv Vitaly Lomov:
chmod 666 file_name
Thank you a lot.
Kolbjoern
