and if I don't have middle click ?
and if I don't have middle click ? Cristian Secară 20 May 21:10
  and if I don't have middle click ? Liam R E Quin 21 May 01:21
Cristian Secară
2012-05-20 21:10:42 UTC (almost 13 years ago)
I wanted to (ex)change a color of a simple png image, so I tried to use Colors -> Map -> Color Exchange... tool.
There I am invited to "Middle-click inside preview to pick "From color"". Where to middle click ? I only have a two button touchpad. I switched the working place to my main dektop computer where the wheel button is set to magnify function. I had to change the wheel button to "middle click" function just to be able to pick the "From color" from the original image.
I suppose I could use previously the color picker, write down the desired color value and then enter manually the value in the "From color" area of the Color exchange, but what is then the purpose of all features of the tool ?
Cristi
Liam R E Quin
2012-05-21 01:21:58 UTC (almost 13 years ago)
Most Linux setups emulate the middle button if you press the left and right buttons at the same time, if that helps.
Liam
