Quasimode Adjustments -- fastest adjustments [demo included]
7 of 7 messages available
Quasimode Adjustments -- fastest adjustments [demo included] yahvuu 19 May 14:29
  Quasimode Adjustments -- fastest adjustments [demo included] Srihari Sriraman 19 May 15:47
   Quasimode Adjustments -- fastest adjustments [demo included] Srihari Sriraman 19 May 16:45
    Quasimode Adjustments -- fastest adjustments [demo included] gfxuser 19 May 17:37
     Quasimode Adjustments -- fastest adjustments [demo included] yahvuu 20 May 11:42
  Quasimode Adjustments -- fastest adjustments [demo included] Alexandre Prokoudine 19 May 17:55
  Quasimode Adjustments -- fastest adjustments [demo included] peter sikking 19 May 22:18
yahvuu
2012-05-19 14:29:18 UTC (almost 13 years ago)
Dear all,
for your inspiration, here's the fastest way to perform adjustments that i can think of:
While pressing a shortcut key - the corresponding slider gets displayed right under the pointer - moving the pointer left-right immediately performs the adjustment. To commit, simply release the key.
You may try the following channel mixer demo to test-drive the interaction: https://sites.google.com/site/yahvuu/stuff/quasimode-adjust-demo.swf?attredirects=0
For the Flash-averse, there's also a screenshot available: http://yahvuu.files.wordpress.com/2009/08/quasimode-adjust.png
The rationale behind is that most of the adjustments are relative adjustments by nature, by which i mean that the absolute numbers are mostly irrelevant. The desired amount of the effect gets determined by applying a bit more or less of it until it looks right.
Grabbing the slider handle is only cognitive burden here, which can be shortcut away.
enjoy, yahvuu
PS: Flash demos do not fit the UI brainstorm well, so i'm posting here
Srihari Sriraman
2012-05-19 15:47:57 UTC (almost 13 years ago)
I had a similar idea and I was wondering how I could put something like this into words.
Awesome! Could be great for Gimp!
On Sat, May 19, 2012 at 7:59 PM, yahvuu wrote:
Dear all,
enjoy,
yahvuu
PS: Flash demos do not fit the UI brainstorm well, so i'm posting here _______________________________________________ gimp-developer-list mailing list
gimp-developer-list@gnome.org
Srihari Sriraman
2012-05-19 16:45:50 UTC (almost 13 years ago)
A few more thoughts on the shortcut+slide:
- Horizontal sliding could adjust *coarse* and vertical sliding could do the *fine* adjustment. This would map to the adjustment shown in the corresponding GimpSpinScale and could perhaps compromise the need to show the sliders on canvas. This would also cover the GtkSpinButton, GtkScale, GtkExpander.
- Numbers [0-9] (as in the demo) could be very good shortcuts. 0-opacity, 1-size, 2-rate...9-xyz. One could simply look in the tool options for the shortcut key (shown against each parameter) corresponding to the parameter he wants to adjust.
- *GtkComboBoxes* that form almost another half of the tool options could also work with the slider. User would do the *[shortcut+slide] to scroll through list* and let go to choose the currently highlighted.
- *Gtk[Check/Radio]Buttons* could just toggle with the shortcut number/key.
So each parameter/option in the tool options has a number-shortcut irrespective of the slide-ability.
This does not include GtkEntries however. Not sure if they are very vital though.
Dear all,
enjoy,
yahvuu
*Regards,
*Srihari Sriraman
gfxuser
2012-05-19 17:37:55 UTC (almost 13 years ago)
A few more thoughts on the shortcut+slide: [...]
* Numbers [0-9] (as in the demo) could be very good shortcuts. 0-opacity, 1-size, 2-rate...9-xyz. One could simply look in the tool options for the shortcut key (shown against each parameter) corresponding to the parameter he wants to adjust.
* *Gtk[Check/Radio]Buttons* could just toggle with the shortcut number/key.
First of all: Yahvuu, this is great! I would like to see it in GIMP. Which editor did you use to create this? IMHO the numbers could be replaced by the well known concept of accelerator keys, for instance &Brightness (B will become underlined in the dialog). Unlike numbers they don't eat space, are also visible for the user and the user can keep them easier in mind like abstract numbers. But I guess, it was your main intention to show the principle and it's well done!
Best regards,
grafxuser
2012-05-19 17:55:25 UTC (almost 13 years ago)
On Sat, May 19, 2012 at 6:29 PM, yahvuu wrote:
Dear all,
This kind of interaction is already implemented in the Brightness/Contrast tool.
Try activating it and dragging the mouse pointer on the image
A similar interaction for Curves was inrtroduced in Photoshop CS5.
peter sikking
2012-05-19 22:18:01 UTC (almost 13 years ago)
nice brainstorm.
there are quite a few catches, but I am not going to spoil the brainstorm spirit with those.
to push this forward: I see this fully relies on the dialog being there (for multiple reasons) with the sliders (and other controls) being there (and taking screen real estate) and then the shortcuts show one slider/control at the time.
the question is: can that be combined?
that is the next level...
--ps
http://blog.mmiworks.net: on interaction architecture
yahvuu
2012-05-20 11:42:09 UTC (almost 13 years ago)
Am 19.05.2012 19:37, schrieb gfxuser:
the demo is written in Actionscript, using Vim. Sources are now available here: https://sites.google.com/site/yahvuu/stuff/quasimode-adjust-demo.zip?attredirects=0&d=1
best regards, yahvuu
