Cage-Tool performance
Cage-Tool performance Anke Lange 18 May 06:44
  Cage-Tool performance Anke Lange 18 May 06:52
   Cage-Tool performance Alexia Death 18 May 08:01
    Cage-Tool performance Anke Lange 18 May 08:17
Anke Lange
2012-05-18 06:44:09 UTC (almost 13 years ago)
Hi
First of all it is a great tool! And I love it. but I found some strange behaviour, so before I start a new bugreport, I wanted to ask you, if this is a bug or just something that's got to do with my system (Linux Xubuntu)
First: when I made a cage and want to adjust the knots, I can't. I have to create a new cage. But when I create the cage new and close it, it cuts my picture into bits. The only way to avoid this, yet, is to restart Gimp and load the motiv new. Is there another way around this?
Second: I tried out, whether I get a difference in making a cage closer to the motif or leaving a wider gap between motif and cage. Using the adjustment of filling the background with color.
Normally, the background becomes transparent, when I use the option, but when I create a cage on the edge of the motif, the background becomes filled with a part-transperent background.
I made some pictures of this:
http://ws.kreativ-workshops.net/gimp2-8/einst/screens/bild384.png
Thanks in advance.
Anke
Anke Lange
An der Landwehr 25
49076 Osnabrck
Telefon 0541 6004299
gimp-werkstatt@gmx.de
www.kreativ-workshops.net
www.gimp-werkstatt.de
www.kompozer-web.de
gimp-developer-list@gnome.org
Anke Lange
2012-05-18 06:52:54 UTC (almost 13 years ago)
ups - the second picture-link was wrong
http://ws.kreativ-workshops.net/gimp2-8/einst/screens/bild386.png
Am 18.05.2012 08:44, schrieb Anke Lange:
Hi
Thanks in advance.
Anke
Anke Lange
An der Landwehr 25
49076 Osnabrck
www.kompozer-web.de
Alexia Death
2012-05-18 08:01:34 UTC (almost 13 years ago)
Yes you can. Close the cage, then in tool options switch to "Create or edit mode". Then you can adjust the cage untill you switch back to transform mode.
Cage transform is only defined for the interior of the cage. It's a limitation of the algorithm. The fill works based on the pixel under your first point. It's ideal operating environment is an element on a separate layer of a larger canvas with transparent bg. Cage is somewhat special transform. It strives to be shape preserving.
Anke Lange
2012-05-18 08:17:05 UTC (almost 13 years ago)
Thanks Alexia
that does help :)
by the way, the examples I made were made on transparent background, I only added a white layer to make it easier to see the cage.
Anke
Am 18.05.2012 10:01, schrieb Alexia Death:
Anke Lange
An der Landwehr 25
49076 Osnabrck
www.kompozer-web.de
