color.po placeholder
color.po placeholder Kolbjørn Stuestøl 14 May 10:30
  color.po placeholder Ulf-D. Ehlert 14 May 18:48
   color.po placeholder Julien Hardelin 15 May 05:36
   color.po placeholder Kolbjørn Stuestøl 15 May 09:24
Kolbjørn Stuestøl
2012-05-14 10:30:48 UTC (almost 13 years ago)
In po/toolbox/color.po I am not able to translate whats inside the in
#: src/toolbox/color/overview.xml:149(para) msgid " instead?
Kolbjoern Stuestoel
Ulf-D. Ehlert
2012-05-14 18:48:36 UTC (almost 13 years ago)
Some suggestions?
Looks like xsltproc doesn't like
some text
so you should change the source code (example attached). (IMHO there's no reason to e list items - we could better use a different type of list instead.)
BTW: "The green cross" comes up with color #80A8D3 on my screen (Windows 7). Perhaps naming it "The cross" instead?
Yes, of course.
Ulf
Beten heißt den Himmel melken wollen.
		-- Karlheinz Deschner
Julien Hardelin
2012-05-15 05:36:30 UTC (almost 13 years ago)
Why you don't fix that directly in xml files? I feel very alone in front of this huge Help.
Julien
Some suggestions?
some text
so you should change the source code (example attached). (IMHO there's no reason toe list items - we could better use a different type of list instead.)
Yes, of course.
Ulf
_______________________________________________ gimp-docs-list mailing list
gimp-docs-list@gnome.org
http://mail.gnome.org/mailman/listinfo/gimp-docs-list
Kolbjørn Stuestøl
2012-05-15 09:24:53 UTC (almost 13 years ago)
Den 14.05.2012 20:48, skreiv Ulf-D. Ehlert:
Some suggestions?
some text
Yes, it works.
I have only tried it by "make ... draft", but the sentences got translated. Have to check it out the usual ways before uploading the changed xml file. Changed the green cross to The cross too. I'll push it this evening i hope.
And to Julien: You are doing a great job! (Yes, I see your "fingerprints" all over the new manual).
Thank you Kolbjoern
Yes, of course.
Ulf
