Fwd: Can't build gegl lately
Fwd: Can't build gegl lately Patrick Horgan 12 May 18:10
Patrick Horgan
2012-05-12 18:10:51 UTC (almost 13 years ago)
I don't get all the way through a gegl build from git trunk lately. after git pull && make distclean && ./autogen.sh && make
On Linux dell 3.2.0-24-generic-pae #38-Ubuntu SMP Tue May 1 16:40:26 UTC 2012 i686 i686 i386 GNU/Linux
using gcc-4.6.real (Ubuntu/Linaro 4.6.3-1ubuntu5) 4.6.3
Build dies in gegl/docs/gallery running gegl/bin/.libs/lt-gegl.
First error is shown below. Is this a known thing? Is there a simple fix? Should I track it down? Is it my environment? Where is it finding two of every plugin?
make[4]: Entering directory `/usr/local/gegl/docs/gallery' --[Updating sample compositions]--
./clones.xml
(lt-gegl:27473): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglOpPlugIn-affine'.
(lt-gegl:27473): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglOpPlugIn-rotate'.
(lt-gegl:27473): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglOpPlugIn-scale'.
(lt-gegl:27473): GLib-GObject-CRITICAL **: g_type_register_dynamic: assertion `parent_type > 0' failed
(lt-gegl:27473): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglOpPlugIn-shear'.
(lt-gegl:27473): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglOpPlugIn-translate'.
(lt-gegl:27473): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglOpPlugIn-reflect'.
(lt-gegl:27473): GLib-GObject-WARNING **: Two different plugins tried to register 'GeglOpPlugIn-transform'.
(lt-gegl:27473): GLib-GObject-WARNING **: specified class size for type `GeglOpPlugIn-affine' is smaller than the parent type's `GeglOperationFilter' class size
*** glibc detected *** /usr/local/gegl/bin/.libs/lt-gegl: malloc(): memory corruption: 0x0909c7b0 ***
======= Backtrace: =========
/lib/i386-linux-gnu/libc.so.6(+0x73e42)[0xb743de42] /lib/i386-linux-gnu/libc.so.6(+0x75905)[0xb743f905] /lib/i386-linux-gnu/libc.so.6(__libc_calloc+0xb6)[0xb7442d46] /usr/local/lib/libglib-2.0.so.0(+0x4c6d3)[0xb75db6d3] /usr/local/lib/libglib-2.0.so.0(g_malloc0+0x2b)[0xb75dbe1b] /usr/local/lib/libglib-2.0.so.0(g_hash_table_new_full+0x88)[0xb75c50c8] /usr/local/gegl/gegl/.libs/libgegl-0.2.so.0(+0x34ef5)[0xb776aef5] /usr/local/lib/libgobject-2.0.so.0(g_type_class_ref+0x2e1)[0xb76e2801] /usr/local/gegl/gegl/.libs/libgegl-0.2.so.0(+0x3b853)[0xb7771853] /usr/local/gegl/gegl/.libs/libgegl-0.2.so.0(+0x3b8be)[0xb77718be] /usr/local/gegl/gegl/.libs/libgegl-0.2.so.0(gegl_operation_gtype_from_name+0xa0)[0xb7771980] /usr/local/gegl/gegl/.libs/libgegl-0.2.so.0(+0x4068a)[0xb777668a] /usr/local/lib/libgobject-2.0.so.0(+0x12383)[0xb76c7383] /usr/local/lib/libgobject-2.0.so.0(g_object_newv+0x2d9)[0xb76c8a19] /usr/local/lib/libgobject-2.0.so.0(g_object_new_valist+0x223)[0xb76c9263] /usr/local/lib/libgobject-2.0.so.0(g_object_new+0x80)[0xb76c94c0] /usr/local/gegl/gegl/.libs/libgegl-0.2.so.0(+0x14185)[0xb774a185] /usr/local/lib/libglib-2.0.so.0(+0x49c2c)[0xb75d8c2c] /usr/local/lib/libglib-2.0.so.0(g_markup_parse_context_parse+0xe47)[0xb75da357] /usr/local/gegl/gegl/.libs/libgegl-0.2.so.0(gegl_node_new_from_xml+0xc4)[0xb774b664] /usr/local/gegl/bin/.libs/lt-gegl(main+0xc2)[0x8049192] /lib/i386-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0xb73e34d3] /usr/local/gegl/bin/.libs/lt-gegl[0x804982d] ======= Memory map: ========
08048000-0804d000 r-xp 00000000 08:06 7823365 /usr/local/gegl/bin/.libs/lt-gegl
0804d000-0804e000 r--p 00004000 08:06 7823365 /usr/local/gegl/bin/.libs/lt-gegl
0804e000-0804f000 rw-p 00005000 08:06 7823365 /usr/local/gegl/bin/.libs/lt-gegl
09060000-090fe000 rw-p 00000000 00:00 0 [heap] b523f000-b52c3000 r-xp 00000000 08:06 9185488 /usr/lib/libdirac_encoder.so.0.1.0
b52c3000-b52c5000 r--p 00083000 08:06 9185488 /usr/lib/libdirac_encoder.so.0.1.0
b52c5000-b52c6000 rw-p 00085000 08:06 9185488 /usr/lib/libdirac_encoder.so.0.1.0
b52c6000-b52c7000 rw-p 00000000 00:00 0 b6206000-b620c000 r-xp 00000000 08:06 71775 /usr/lib/i386-linux-gnu/libogg.so.0.7.1 b620c000-b620d000 r--p 00005000 08:06 71775 /usr/lib/i386-linux-gnu/libogg.so.0.7.1 b620d000-b620e000 rw-p 00006000 08:06 71775 /usr/lib/i386-linux-gnu/libogg.so.0.7.1 b620e000-b6237000 r-xp 00000000 08:06 9246044 /usr/lib/i386-linux-gnu/libvorbis.so.0.4.5 b6237000-b6238000 r--p 00028000 08:06 9246044 /usr/lib/i386-linux-gnu/libvorbis.so.0.4.5 b6238000-b6239000 rw-p 00029000 08:06 9246044 /usr/lib/i386-linux-gnu/libvorbis.so.0.4.5 b6239000-b639f000 r-xp 00000000 08:06 9246038 /usr/lib/i386-linux-gnu/libvorbisenc.so.2.0.8 b639f000-b63b0000 r--p 00165000 08:06 9246038 /usr/lib/i386-linux-gnu/libvorbisenc.so.2.0.8 b63b0000-b63b1000 rw-p 00176000 08:06 9246038 /usr/lib/i386-linux-gnu/libvorbisenc.so.2.0.8 b63b1000-b63fd000 r-xp 00000000 08:06 9246049 /usr/lib/i386-linux-gnu/libFLAC.so.8.2.0 b63fd000-b63fe000 r--p 0004b000 08:06 9246049 /usr/lib/i386-linux-gnu/libFLAC.so.8.2.0 b63fe000-b63ff000 rw-p 0004c000 08:06 9246049 /usr/lib/i386-linux-gnu/libFLAC.so.8.2.0 b63ff000-b6404000 r-xp 00000000 08:06 71714 /usr/lib/i386-linux-gnu/libXdmcp.so.6.0.0 b6404000-b6405000 r--p 00004000 08:06 71714 /usr/lib/i386-linux-gnu/libXdmcp.so.6.0.0 b6405000-b6406000 rw-p 00005000 08:06 71714 /usr/lib/i386-linux-gnu/libXdmcp.so.6.0.0 b6406000-b6408000 r-xp 00000000 08:06 71710 /usr/lib/i386-linux-gnu/libXau.so.6.0.0 b6408000-b6409000 r--p 00001000 08:06 71710 /usr/lib/i386-linux-gnu/libXau.so.6.0.0 b6409000-b640a000 rw-p 00002000 08:06 71710 /usr/lib/i386-linux-gnu/libXau.so.6.0.0 b640a000-b640f000 r-xp 00000000 08:06 18730033 /usr/lib/i386-linux-gnu/libasyncns.so.0.3.1 b640f000-b6410000 r--p 00004000 08:06 18730033 /usr/lib/i386-linux-gnu/libasyncns.so.0.3.1 b6410000-b6411000 rw-p 00005000 08:06 18730033 /usr/lib/i386-linux-gnu/libasyncns.so.0.3.1 b6411000-b647d000 r-xp 00000000 08:06 9246054 /usr/lib/i386-linux-gnu/libsndfile.so.1.0.25 b647d000-b647e000 r--p 0006c000 08:06 9246054 /usr/lib/i386-linux-gnu/libsndfile.so.1.0.25 b647e000-b647f000 rw-p 0006d000 08:06 9246054 /usr/lib/i386-linux-gnu/libsndfile.so.1.0.25 b647f000-b6483000 rw-p 00000000 00:00 0 b6483000-b648b000 r-xp 00000000 08:06 11153420 /lib/i386-linux-gnu/libwrap.so.0.7.6 b648b000-b648c000 r--p 00007000 08:06 11153420 /lib/i386-linux-gnu/libwrap.so.0.7.6 b648c000-b648d000 rw-p 00008000 08:06 11153420 /lib/i386-linux-gnu/libwrap.so.0.7.6 b65fc000-b661b000 r-xp 00000000 08:06 71718 /usr/lib/i386-linux-gnu/libxcb.so.1.1.0 b661b000-b661c000 r--p 0001f000 08:06 71718 /usr/lib/i386-linux-gnu/libxcb.so.1.1.0 b661c000-b661d000 rw-p 00020000 08:06 71718 /usr/lib/i386-linux-gnu/libxcb.so.1.1.0 b661d000-b6664000 r-xp 00000000 08:06 15125551 /lib/i386-linux-gnu/libdbus-1.so.3.5.8 b6664000-b6665000 r--p 00046000 08:06 15125551 /lib/i386-linux-gnu/libdbus-1.so.3.5.8 b6665000-b6666000 rw-p 00047000 08:06 15125551 /lib/i386-linux-gnu/libdbus-1.so.3.5.8 b6666000-b666c000 r-xp 00000000 08:06 71808 /usr/lib/i386-linux-gnu/libjson.so.0.0.1 b666c000-b666d000 r--p 00005000 08:06 71808 /usr/lib/i386-linux-gnu/libjson.so.0.0.1 b666d000-b666e000 rw-p 00006000 08:06 71808 /usr/lib/i386-linux-gnu/libjson.so.0.0.1 b666e000-b66d1000 r-xp 00000000 08:06 71870 /usr/lib/i386-linux-gnu/libpulsecommon-1.1.so b66d1000-b66d2000 r--p 00062000 08:06 71870 /usr/lib/i386-linux-gnu/libpulsecommon-1.1.so b66d2000-b66d3000 rw-p 00063000 08:06 71870 /usr/lib/i386-linux-gnu/libpulsecommon-1.1.so b68e4000-b6930000 r-xp 00000000 08:06 9246371 /usr/lib/i386-linux-gnu/libpulse.so.0.13.5 b6930000-b6931000 r--p 0004b000 08:06 9246371 /usr/lib/i386-linux-gnu/libpulse.so.0.13.5 b6931000-b6932000 rw-p 0004c000 08:06 9246371 /usr/lib/i386-linux-gnu/libpulse.so.0.13.5 b6932000-b6935000 r-xp 00000000 08:06 71868 /usr/lib/i386-linux-gnu/libpulse-simple.so.0.0.3 b6935000-b6936000 r--p 00002000 08:06 71868 /usr/lib/i386-linux-gnu/libpulse-simple.so.0.0.3 b6936000-b6937000 rw-p 00003000 08:06 71868 /usr/lib/i386-linux-gnu/libpulse-simple.so.0.0.3 b6a1c000-b6a60000 r-xp 00000000 08:06 71954 /usr/lib/i386-linux-gnu/libjpeg.so.8.0.2/bin/bash: line 1: 27473 Aborted (core dumped) GEGL_DEBUG_TIME=yes GEGL_SWAP=RAM GEGL_PATH=../../operations ../../bin/gegl clones.xml -o `echo clones.png | sed s?./??` > `echo clones.png | sed s?./?? | sed -e s/png/txt/` make[5]: *** [clones.png] Error 134
