GIMP FxFoundry using GEGL?
GIMP FxFoundry using GEGL? gfxuser 02 May 06:59
  GIMP FxFoundry using GEGL? Alexia Death 02 May 09:32
   GIMP FxFoundry using GEGL? Kevin Cozens 03 May 03:06
gfxuser
2012-05-02 06:59:42 UTC (almost 13 years ago)
lately I found this very promising plug-in collection made by two well-known persons of this list ;-)
Will or need the plug-ins therein be ported to GEGL or do they use GEGL out of the box through the reworked PDP API?
Thanks, grafxuser
Alexia Death
2012-05-02 09:32:32 UTC (almost 13 years ago)
GIMP-s plugin appi is not slated to change afaik, and fx foundry is only scriptfu scripts. They should just work with the geglified gimp...
Thanks, grafxuser
gimp-developer-list@gnome.org
Kevin Cozens
2012-05-03 03:06:25 UTC (almost 13 years ago)
The API isn't likely to under go any changes until work really begins on 3.0. There were a lot of deprecations in 2.8 and I have heard there will be a lot more in the 3.0 version.
