help building help
help building help Marco Ciampa 29 Apr 14:41
  help building help Ulf-D. Ehlert 29 Apr 16:55
   help building help Marco Ciampa 29 Apr 17:27
    help building help Ulf-D. Ehlert 30 Apr 11:12
help building help Marco Ciampa 29 Apr 17:00
Marco Ciampa
2012-04-29 14:41:12 UTC (almost 13 years ago)
help building help
I've just committed two small fix in
src/dialogs/export-file-dialog.xml
how can I make "make" aware of it?
If I do a
make status-it
it does not update the po files.
make clean
does not help.
Any hint?
Ulf-D. Ehlert
2012-04-29 16:55:09 UTC (almost 13 years ago)
help building help
This should work automatically, 'make' checks the timestamps.
If I do a
make status-it
Most likely, your po file is newer than the source (xml) file. Check it with
$ ls -l src/dialogs/export-file-dialog.xml po/it/dialogs.po
make clean
does not help.
Any hint?
Simply touch 'src/dialogs/export-file-dialog.xml' and try again:
$ touch -c src/dialogs/export-file-dialog.xml $ make po-it
Ulf
Marco Ciampa
2012-04-29 17:00:59 UTC (almost 13 years ago)
help building help
On Mon, Apr 30, 2012 at 01:15:02AM +0900, RyōTa SimaMoto wrote:
To get any updated PO files, run 'make po-it'.
Already tested, it does not work.
If this
command happens not to work as you expect, it requires updating the template file manually, so you should run 'make pot',
Done. It does not work.
or 'make pot/dialogs.pot' in more specific
way, then you can get it by 'make po/it/dialogs.po'.
THIS worked! Thanks!
That is all what I know. I will be glad if this gives help for you a bit more.
Definitely! Many thanks!
Maybe it is missing some makefile test?
Marco Ciampa
2012-04-29 17:27:58 UTC (almost 13 years ago)
help building help
If I do a
make status-it
make clean
does not help.
Any hint?
Umf perhaps I now understand what is going on here: I have modified the xml file during the editing of a .po file. I've modified the xml file and _then_ I've saved the .po file.
Is there a method to reset it all without 'touch'ing all xml files?
Ulf-D. Ehlert
2012-04-30 11:12:42 UTC (almost 13 years ago)
help building help
Hmm, what do you mean with "reset"? You can force re-making a po file with
$ make po/it/path/to/file.po
(I guess your problem was exactly the reason why I added this.)
Additionally, we could add a new make command/target, e.g.
$ make force-po-it
to re-make *all* your po files. You still had to remember that this command exists...
Ulf
Mitraut denen, die da sagen, dass Gott auf ihrer Seite steht.
Sie sind nur so nah ihrem Gott, weil sie so fern dem Menschen sind.
		-- Michael Schmidt-Salomon
gimp-docs-list mailing list
gimp-docs-list@gnome.org
http://mail.gnome.org/mailman/listinfo/gimp-docs-list
