javick
javick Ivano Arrighetta 29 Apr 13:33
javick Ivano Arrighetta 30 Apr 02:40
  javick gfxuser 30 Apr 05:56
javick Ivano Arrighetta 30 Apr 05:32
javick2 Ivano Arrighetta 30 Apr 09:07
  javick2 Alexandre Prokoudine 30 Apr 09:14
Ivano Arrighetta
2012-04-29 13:33:43 UTC (almost 13 years ago)
javick
Ivano Arrighetta
2012-04-30 02:40:45 UTC (almost 13 years ago)
javick
sorry, i posted a wrong url.
right one:
https://docs.google.com/document/d/1Lut6Y6Xe-4ScR9G4Fg6EorTuSp0JKuTP6QRRzrk0kSM/edit
Inviato da iPhone
Ivano Arrighetta
2012-04-30 05:32:46 UTC (almost 13 years ago)
javick
Someone pointed me to videojack, it's almost the same thing
Inviato da iPhone
gfxuser
2012-04-30 05:56:07 UTC (almost 13 years ago)
javick
Am 30.04.12 04:40, schrieb Ivano Arrighetta:
right one:
Inviato da iPhone _______________________________________________ gimp-developer-list mailing list
gimp-developer-list@gnome.org
it was nice if you could explain here a bit more, what you're trying to tell.
So I read your doc and as far as I can see you want GIMP to send image data to an application which converts them to sounds and vice versa, right? Have you heard of Metasynth, which generates sounds from images? For the other way around (converting sound data to images), there are already visualization plug-ins for many media players, like G-Force and so on. You could capture their output from screen and paste it into GIMP to do further artwork with them. But I doubt it would be sufficient to act as a VJ, since GIMP is more an image editor than a video editor.
Best regards,
grafxuser
Ivano Arrighetta
2012-04-30 09:07:08 UTC (almost 13 years ago)
javick2
signal processing and JAVICK in theory - draft 2 -https://docs.google.com/document/d/19EP2CgK6_EqsZ_nU6YSHcWsmC8ciFs7y1WWmTQw8J2c/edit
Inviato da iPhone
2012-04-30 09:14:37 UTC (almost 13 years ago)
javick2
Hi Ivano,
Is there a particular reason that you are sending this to 100% irrelevant lists while you could be sending it to _relevant_ ones (such as linux-audio-dev@)?
