manual bug - dotted lines
manual bug - dotted lines Marco Ciampa 28 Apr 13:22
  manual bug - dotted lines Julien Hardelin 29 Apr 06:53
   manual bug - dotted lines Liam R E Quin 29 Apr 06:59
    manual bug - dotted lines Marco Ciampa 29 Apr 10:55
     manual bug - dotted lines Julien Hardelin 29 Apr 13:31
Marco Ciampa
2012-04-28 13:22:51 UTC (almost 13 years ago)
#: src/concepts/imagewindow.xml:322(para) msgid ""
I do not see any dotted line in single window mode... is it a reminescent of an old GIMP-2.7 single window test mode?
Julien Hardelin
2012-04-29 06:53:48 UTC (almost 13 years ago)
Le 28/04/2012 15:22, Marco Ciampa a crit :
The version I used is that of the git repository on 2012-04-08. I just installed gimp-2.8.0-RC1, which was released also on the same date, and still I have these dotted lines in single-window mode!
I use opensuse-12.1 with KDE-4.4.4
gimp-docs-list mailing list
gimp-docs-list@gnome.org
http://mail.gnome.org/mailman/listinfo/gimp-docs-list
Liam R E Quin
2012-04-29 06:59:16 UTC (almost 13 years ago)
I've never seen dotted lines, but there's a thin vertical strip with a simulated grip half-way down. I think it may depend on your gtk+ theme.
Liam
I use opensuse-12.1 with KDE-4.4.4 _______________________________________________ gimp-docs-list mailing list
Ankh: irc.sorcery.net irc.gnome.org www.advogato.org
Marco Ciampa
2012-04-29 10:55:04 UTC (almost 13 years ago)
Liam
I use Ubuntu 12.04 with Unity.
It could change in:
...depending on your system and you current theme loaded, you may notice some dotted lines, just two handles, some other graphics or simply nothing, separating the image area from the lateral panels. Anyway, visible or not, clicking and draggingon those areas, you can change the panel width inside the GIMP main window...
or something similar...
Marco Ciampa
| Linux User  #78271 |
| FSFE fellow   #364 |
Julien Hardelin
2012-04-29 13:31:44 UTC (almost 13 years ago)
Le 29/04/2012 12:55, Marco Ciampa a crit :
Liam
It could change in:
OK, I'll fix that.
Thank you for the feedback
