that typing business...
11 of 11 messages available
that typing business... peter sikking 27 Apr 21:23
  that typing business... gg 27 Apr 22:38
  that typing business... Øyvind Kolås 28 Apr 07:24
   that typing business... Ragnar Brynjúlfsson 28 Apr 07:49
that typing business... Miles Bader 28 Apr 01:05
  that typing business... gg 28 Apr 05:15
  that typing business... Alexia Death 28 Apr 05:27
   that typing business... gfxuser 28 Apr 05:54
   that typing business... Liam R E Quin 28 Apr 06:15
that typing business... Miles Bader 28 Apr 06:19
peter sikking
2012-04-27 21:23:52 UTC (almost 13 years ago)
OK, I cannot resist quoting this review:
it uses GIMP to discuss ubuntus HUD. but then:
Of course GIMP is an app that lends itself to the mouse so switching to the keyboard to use the HUD isn't always faster.
if a software reviewer, with (I postulate) nowhere near the speed demands of our core users, can see the flaw, then...
yes, context is everything in interaction design,
--ps
http://blog.mmiworks.net: on interaction architecture
gimp-developer-list@gnome.org
gg
2012-04-27 22:38:05 UTC (almost 13 years ago)
--ps
An interface that makes you drop your focus on the mouse pointer, look down at the keyboard and them back at a different part of the screen to see whether it has found a match ...
We called it heads up display because once you lowered your head(s) to look at the keyboard, you'll need to raise your _heads up_ again.
Clever , no ?
/gg
Miles Bader
2012-04-28 01:05:57 UTC (almost 13 years ago)
gg writes:
Wait, you look at the keyboard when you use it...?
-miles
gg
2012-04-28 05:15:02 UTC (almost 13 years ago)
On 04/28/12 03:05, Miles Bader wrote:
gg writes:
-miles
I'm quite capable of touch typing when dealing with text, that's what I'm doing now.
However, if I'm working with one hand on the mouse I'm likely to have the other hand at rest , not hovering over the keyboard either.
Now I could try stabbing around in the dark like a blind man and locate the keyboard by Braille. I reality I'm going to look down to see where it is and where the alt key is since that would be two orders of magnitude quicker.
Assuming the user is using a real mouse of graphics pad as pointing device HUD makes you break the flow to swap back and forth betweem mouse and keyboard.
This makes such an interface more of a down-up-down : DUD.
/gg
Alexia Death
2012-04-28 05:27:03 UTC (almost 13 years ago)
Hell yes. It's not blind typing. In GIMP you very seldom get away with one key. It's all two-finger or 3 finger shortcuts. Even Ctrl-S can pose problems without looking if you have two laptops that have alternating Ctrl and Fn key positions. Plays havoc on muscle memory, that one.
gfxuser
2012-04-28 05:54:45 UTC (almost 13 years ago)
do you mean this needs to be improved?
Best regards,
grafxuser
Liam R E Quin
2012-04-28 06:15:21 UTC (almost 13 years ago)
Hmm, I generally don't look at the keyboard, even when switching between laptop and desktop, and generally work with one hand on the mouse and one on the keyboard.
I taught myself some of the key sequences to navigate menus too, e.g. alt-c c for curves, but then found they don't work in full screen mode; it'd be great if Alt brought up the menu bar in full screen mode.
Liam
Liam R E Quin
2012-04-28 06:15:38 UTC (almost 13 years ago)
Liam
Miles Bader
2012-04-28 06:19:51 UTC (almost 13 years ago)
Alexia Death writes:
Hmm, I'm guessing you're not an Emacs user... :]
-miles
Øyvind Kolås
2012-04-28 07:24:31 UTC (almost 13 years ago)
This is not to say that typing will be faster than hunting through the menus of GIMP to find grid, checkerboard or unsharp mask that are hidden deep in the menu-hierarchy of GIMP. Such a type-to search based system could also be made to adapt to the user and by default present the recently top N used filters/actions without needing to type - kind of an "invoke recent action" that gives you a list of recently performed actions and allows you to pick one with the pointing device. Personally I use
                        -- William Gibson
http://pippin.gimp.org/              http://ffii.org/
Ragnar Brynjúlfsson
2012-04-28 07:49:05 UTC (almost 13 years ago)
I tend to use Gimp with easystroke gestures when drawing. I did a tutorial on it a while back, which can be found here. http://www.gimptalk.com/index.php?/topic/36788-tutorial-using-gimp-with-gestures-look-ma-no-keyboard/ It's a bit out of date, but easystroke still works like a charm. I've switched out xvkbd with CellWriter, which has both hand writing recognition and a virtual keyboard.
Gestures are about as fast as keyboard shortcuts, and I find I rarely use more than 10 or so. It's great when working with something like a TabletPC (where the keyboard is folded under the screen) or a CintiQ.
Having used Blender a bit, I do see the use of this kind of menu navigation. Often when I'm looking for a tool I have no idea where is, I'll just type part of the name and find it....sometimes even discovering new features in the process.
Ragnar
p.s. I'm a long time emacs user, that never looks at the keyboard. :)
This is not to say that typing will be faster than hunting through the menus of GIMP to find grid, checkerboard or unsharp mask that are hidden deep in the menu-hierarchy of GIMP. Such a type-to search based system could also be made to adapt to the user and by default present the recently top N used filters/actions without needing to type - kind of an "invoke recent action" that gives you a list of recently performed actions and allows you to pick one with the pointing device. Personally I use s just not very evenly distributed -- William Gibson http://pippin.gimp.org/ http://ffii.org/ _______________________________________________ gimp-developer-list mailing list
