feature request -- reduce my mouse clicking by 90%
feature request -- reduce my mouse clicking by 90% Alec Battles 19 Apr 13:13
  feature request -- reduce my mouse clicking by 90% Bill Skaggs 19 Apr 20:54
  feature request -- reduce my mouse clicking by 90% Joao S. O. Bueno 20 Apr 05:19
Alec Battles
2012-04-19 13:13:23 UTC (about 13 years ago)
hi. i've had a feature request i've wanted to make for ages now, so i figured i might as well make it.
if anyone's sitting there thinking, wow i'd like to do some gimp hacking, please read on.
the problem is this. i'm a command line cowboy mostly, and i usually opt for an imagemagick solution much quicker than i opt for a gimp solution. i understand that this has mostly to do with temperament.
there are times when i need gimp, though. and when i need it, i usually like it.
except for one thing. i tend to open a lot of *windows*. sometimes too many.
here's two things that would make my life easier:
1) simple request
i've opened a lot of windows, and i want to be able to save every window in a (variable) directory with a (variable) set of defaults for a (variable) extension. seeing as how gimp seems to save defaults on a per-extension basis, this doesn't seem like it would be too hard.
obviously this would not work for windows that did not yet have filenames assigned, but it would be a huge bonus for me.
2) complicated request
for really complicated guillotines, allow saving guide positions to a 'guide file'. then make a handy way to do all of the slicing via the command line, given a guide file and the image named in the guide file.
Alec
Bill Skaggs
2012-04-19 20:54:25 UTC (about 13 years ago)
The first task would be straightforward to do with a plugin, at least for a limited set of common file types. I suspect the second would be as well, but I've never used the guillotine functions so can't say for sure.
-- Bill
Joao S. O. Bueno
2012-04-20 05:19:18 UTC (about 13 years ago)
1) simple request
Hi -
I can only recoment that you take a little time to learn "driving" GIMP through one of the two scripting languages that have full API access - you can do it either iwth a Python console or a scheme console.
Python, in particular, will give you very flexible and easy ways to "save all open images to a folder using this name pattern". After exploring the possibilities interactively, you can put together what you found out works best in your workflow and create a script or plug-in to do that automatically.
Otherwise, if you want to formalize these feature requests, open them properly at bugzilla.gnome.org - people will forget about them on the list.
Alec
gimp-developer-list@gnome.org
