gimp 2.8 splash screen suggestion
29 of 29 messages available
gimp 2.8 splash screen suggestion Bernhard Stockmann 15 Apr 19:39
  gimp 2.8 splash screen suggestion gfxuser 16 Apr 04:32
   gimp 2.8 splash screen suggestion Alexia Death 16 Apr 07:04
  gimp 2.8 splash screen suggestion Martin Nordholts 16 Apr 08:20
   gimp 2.8 splash screen suggestion Bernhard Stockmann 16 Apr 11:52
    gimp 2.8 splash screen suggestion Martin Nordholts 17 Apr 06:17
     gimp 2.8 splash screen suggestion Simon Budig 17 Apr 13:37
      gimp 2.8 splash screen suggestion Alexia Death 17 Apr 16:47
     gimp 2.8 splash screen suggestion John Harris 17 Apr 14:13
      gimp 2.8 splash screen suggestion Jeremy Morton 17 Apr 17:35
       gimp 2.8 splash screen suggestion gespertino@gmail.com 17 Apr 20:04
        gimp 2.8 splash screen suggestion gespertino@gmail.com 17 Apr 21:38
         gimp 2.8 splash screen suggestion Alexandre Prokoudine 17 Apr 22:06
          gimp 2.8 splash screen suggestion gespertino@gmail.com 17 Apr 22:16
           gimp 2.8 splash screen suggestion John Harris 17 Apr 22:25
         gimp 2.8 splash screen suggestion Kevin Cozens 17 Apr 23:23
          gimp 2.8 splash screen suggestion Alexandre Prokoudine 17 Apr 23:49
           gimp 2.8 splash screen suggestion Kevin Cozens 18 Apr 00:02
           gimp 2.8 splash screen suggestion Burnie West 18 Apr 04:11
            gimp 2.8 splash screen suggestion Alexia Death 18 Apr 05:45
          gimp 2.8 splash screen suggestion John Harris 18 Apr 13:01
  gimp 2.8 splash screen suggestion mk 16 Apr 12:48
gimp 2.8 splash screen suggestion Devvv 25 Apr 08:59
  gimp 2.8 splash screen suggestion gespertino@gmail.com 25 Apr 12:59
   gimp 2.8 splash screen suggestion Bernhard Stockmann 25 Apr 14:39
    gimp 2.8 splash screen suggestion gespertino@gmail.com 25 Apr 16:22
     gimp 2.8 splash screen suggestion gespertino@gmail.com 25 Apr 16:23
  gimp 2.8 splash screen suggestion Kevin Cozens 27 Apr 13:59
   gimp 2.8 splash screen suggestion Alexandre Prokoudine 02 May 10:16
Bernhard Stockmann
2012-04-15 19:39:49 UTC (about 13 years ago)
hey everyone!
I made a startup splash screen in GIMP for GIMP 2.8. also filed a bug on it here: https://bugzilla.gnome.org/show_bug.cgi?id=674154
If you like it you can use it!
Is there another way to submit splash screens? Or are there any official guidelines?
gfxuser
2012-04-16 04:32:40 UTC (about 13 years ago)
Am 15.04.12 21:39, schrieb Bernhard Stockmann:
hey everyone!
+10
Alexia Death
2012-04-16 07:04:04 UTC (about 13 years ago)
Not bad. The dark line going under wilber feels a little bit funny, but I like it in concept. Better than mine in the RC :P
hey everyone!
+10
gimp-developer-list@gnome.org
Martin Nordholts
2012-04-16 08:20:44 UTC (about 13 years ago)
Den 15 april 2012 21:39 skrev Bernhard Stockmann :
hey everyone!
I like it too, except the white line that goes right across Wilber from the bottom left to the upper right. Could you make a new version with that fixed perhaps?
/ Martin
Bernhard Stockmann
2012-04-16 11:52:19 UTC (about 13 years ago)
Am 2012-04-16 10:20, schrieb Martin Nordholts:
Den 15 april 2012 21:39 skrev Bernhard Stockmann:
hey everyone!
/ Martin
I've made a version with Wilber above the lines. Hope you like it more now ;)
see here:
mk
2012-04-16 12:48:05 UTC (about 13 years ago)
Not
bad.
This
is how I would improve it.
The
“GIMP” is the brand. It should dominate the artwork. (Note: Splash is a brand image. It is not a fine arts work that we can stare for hours. It is on the screen for a short period of time. Therefore it should be simple, otherwise, its massage gets lost) The release number is unimportant. A couple months and it will be 3.00 and so on and so forth. Therefore, the brand name (Gimp) should be bigger, it should dominate the artwork and the release number waaaay smaller. Put somewhere at the end of the Gimp text. Centering everything is boring. Also ask yourself, does the white background add anything to the artwork; wouldn't it be better without that?
Every artwork (doesn't matter fine arts or design arts) has a strong hierarchical structure. No element should be there without function. Every element should support the main concept, otherwise the elements start competing for attention and the message gets lost.
Jmak
Sent: Sunday, April 15, 2012 3:39:49 PM
Subject: [Gimp-developer] gimp 2.8 splash screen suggestion
hey everyone!
-- best regards,
bernhard
Martin Nordholts
2012-04-17 06:17:44 UTC (about 13 years ago)
Den 16 april 2012 13:52 skrev Bernhard Stockmann :
see here:
I like it more, but I still think the white diagonal line is too distracting
/ Martin
Simon Budig
2012-04-17 13:37:53 UTC (about 13 years ago)
I am not a fan of this kind of nit-picking. While we have certain requirements for the splash (e.g. to allow for the startup texts etc.) we should try to avoid pleasing everyone with the design, this in general doesn't help, since it dilutes the original artwork.
In particular I prefer the original version of the splash. It has more of an edge and I like the stronger contrast better.
Bye, Simon
John Harris
2012-04-17 14:13:23 UTC (about 13 years ago)
Is it OK if I chime in?
Yes the diagonal lines behind Wilber and across the largest brush are distracting, but I LOVE the overall concept. It's fresh, clean, professional and colorful. The use of a bokeh layer is fantastic and well executed.
The new layer order is much better and shows Wilber properly. The first thing my eye goes to is the 2.8. To me, it carries the same visual weight as Wilber. I am not sure that the version number is the primary focus of a splash screen. Is there another creative element you might replace that with? While we are all celebrating this much anticipated release, the version number is not critically important. Could we completely remove the version number from the splash or at least make it much much smaller? Say 12 to 14 px high and subtle. Or, as an idea that is a bit outside the box. spell it out i.e.
V e r s i o n Two Point Eight.
This could still fit in the bottom of your vertical banner as your third element, yet it would minimize the visual weight.
Also, the white margins on top and bottom seem unnecessary and I find them distracting, especially the bottom. It's quite a bit of empty space and appears unfinished because it carries so much visual weight yet does not serve an immediate purpose that I can see.
Fantastic work so far. Perhaps Gimp's best splash to date!
John H
see here:
/ Martin _______________________________________________ gimp-developer-list mailing list
Alexia Death
2012-04-17 16:47:58 UTC (about 13 years ago)
Heh. I would not complain about that line so much, if it wasnt "crossing out" the label along with the wilber. I like the original translucent wilber more. I dont like the crossing out effect that sharp line gives.
Jeremy Morton
2012-04-17 17:35:43 UTC (about 13 years ago)
On 17/04/2012 15:13, John Harris wrote:
V e r s i o n
Two Point Eight.
Please god no. That sounds seriously cheesy. :-)
2012-04-17 20:04:34 UTC (about 13 years ago)
Hi.
I've been following this discussion, and I'd like to propose an alternative based on this proposal.
I really like the original photo and I think the manipulation doesn't do justice to it, so what about using the original photo instead? It's very nice, has a pretty balanced composition and more or less illustrates one of the features that have been enhanced in 2.8. So I created these splashes for your consideration. I have made two designs: One with the shaded wilber and other using a flat version of wilber (the same used in the empty window).
http://dl.dropbox.com/u/255376/gimp/gimp-splash_gez-V1.png
http://dl.dropbox.com/u/255376/gimp/gimp-splash_gez-V2.png
There's an extra sample with a semitransparent black stripe at the bottom, intended to contain the splash messages. This is optional, since text is readable on the photographic background, so there isn't really need to use it.
http://dl.dropbox.com/u/255376/gimp/gimp-splash_gez-V1b.png
Regarding the typefaces, I used Dave Crossland's Cantarell as placeholder, since it's the default font in Gnome3, I think it should blend pretty good.
However, I've heard that some people is working on a new wordmark for GIMP, so this font choice might be only temporary if the new logo is ready and agreed before the release of 2.8
Kind regards, Gez.
2012-04-17 21:38:33 UTC (about 13 years ago)
After some tweaking...
http://dl.dropbox.com/u/255376/gimp/gimp-splash_gez-V3.png
I like this one better.
Gez.
2012-04-17 22:06:14 UTC (about 13 years ago)
Just remove the whole "GNU blah" stuff :)
Do you really like several lines of centered text? :)
2012-04-17 22:16:12 UTC (about 13 years ago)
2012/4/17 Alexandre Prokoudine :
What lines? :-p
You're right. It sucked. Just tried to do something to avoid the usual name bashing, but I agree that it doesn't work in two lines.
G.
John Harris
2012-04-17 22:25:08 UTC (about 13 years ago)
Looking at Gespertino's and Berhard's versions side by side, and Bernhard's certainly looks more creative. Gespertino's has the look of a straight up layout. While balanced, it feels a bit lacking in "juice" and looks to me to be very "business graphic"
Bernhard's layout speaks to pushing the envelope and deeper creative expressions.
Somewhere in the middle ground perhaps?
What lines? :-p
G. _______________________________________________ gimp-developer-list mailing list
Kevin Cozens
2012-04-17 23:23:49 UTC (about 13 years ago)
If a person was to get picky they could point out that GIMP has more than paint brushes in its toolbox. ;-)
Looks good. Nice and colourful.
2012-04-17 23:49:52 UTC (about 13 years ago)
Personally I wish we had just _one_ splash screen where Wilber goes berserk, bites the brush in half and takes all GIMP haters to cleaners, en masse. Just for fun.
Alas, this would not make us look good.
Kevin Cozens
2012-04-18 00:02:27 UTC (about 13 years ago)
Sounds like a great idea for a splash screen of an upcoming development version, post 2.8.
Burnie West
2012-04-18 04:11:43 UTC (about 13 years ago)
I'm with you on that one, Alexandre - - but on the other side GIMP is SO _ O _ O much fun
Alexia Death
2012-04-18 05:45:39 UTC (about 13 years ago)
In general I like the inital proposal more, if there wasnt that distracting strikethrough line, as is gespertino's v3 wins my favor.
--Alexia
John Harris
2012-04-18 13:01:07 UTC (about 13 years ago)
While this is certainly true, GIMP, along with PS and others like them, fall into a class called "Paint Programs". This may have been the artist's inspiration.
Devvv
2012-04-25 08:59:46 UTC (almost 13 years ago)
yes it was and I'm definitely someone that enjoys colorful things :) but I like the other proposal too, although I find it a bit too simple for a splash screen. nevertheless its looking very serious. good work!
 I finally uploaded 2 more versions with a blurred line and without the line. however I like my initial version little more. it gives some special to it :) what do you think? see bug report for files
--  Bernhard
Von Samsung Mobile gesendet
-------- Original message -------- Subject: Re: [Gimp-developer] gimp 2.8 splash screen suggestion From: John Harris
To: Kevin Cozens
CC: gimp-developer
On 04/17/2012 05:23 PM, Kevin Cozens wrote: On 12-04-17 05:38 PM, gespertino@gmail.com wrote: After some tweaking...
2012-04-25 12:59:25 UTC (almost 13 years ago)
2012/4/25 Devvv :
Much better. Personally I like the second more. It's colorful but it doesn't feel overdone and it definitely left behind the "predefined filter" look it had in its first incarnation. I'm not sure about the typesetting. 2.8 it's sill too large. I also wonder if the solid white band at the bottom will align ok with the splash messages.
I did a quick mockup cloning and blurring the background and making the band semi-transparent. Also changed the typesetting of the logo and made some minor adjustments.
http://dl.dropbox.com/u/255376/gimp/gimp-splash_gez-V4b.png
I don't have the original file so probably quality isn't great, but just to have an idea of what I'm talking about.
What do you think?
Gez.
Bernhard Stockmann
2012-04-25 14:39:04 UTC (almost 13 years ago)
Am 2012-04-25 14:59, schrieb gespertino@gmail.com:
2012/4/25 Devvv:
What do you think?
Gez.
Thanks, gespertino! I uploaded an alternative with your ideas in mind! Can't decide, but contrast is little low now for my personal opinion. Don't you think so? (keep in mind that wilber is a little blurred, i'd yet replace him if more people like this version). https://bugzilla.gnome.org/show_bug.cgi?id=674154
Cheers, Bernhard
2012-04-25 16:22:11 UTC (almost 13 years ago)
I like it!
I'd move the band with the logo to the left a little, maybe 10 or 15 px, to compensate the space around it. It feels like too close to the brushes.
I think it looks pretty good.
It's true that contrast is a little week in type, but it's visible and legible. Regarding the typeface, I chose Cantarell because it's free and it's the default font in Gnome. What font did you use? Is it free? (I'm asking because using a font that isn't free could be problematic for previous releases).
Gez.
2012-04-25 16:23:13 UTC (almost 13 years ago)
2012/4/25 gespertino@gmail.com :
-previous +next :-)
Kevin Cozens
2012-04-27 13:59:22 UTC (almost 13 years ago)
I slightly prefer the last one with the larger Wilber. The only problem I have with it is the "accent" lines (the thin highlight streaks) are no longer running parallel to the angle of the brushes as they were in the image before. If you fix up the angle of the streaks to match the angle of the brushes I'd say we have a winner.
2012-05-02 10:16:36 UTC (almost 13 years ago)
IMO, the area for startup messages is too high, and the logo/GIMP 2.8 part is too close to the upper part.
