Greek translations of gimp-docs
Greek translations of gimp-docs dmtrs32 10 Apr 14:29
  Greek translations of gimp-docs RyōTa SimaMoto 10 Apr 15:16
dmtrs32
2012-04-10 14:29:36 UTC (about 13 years ago)
I've got two issues with the greek translation of gimp-docs: 1. There are 12 unities
a) xml/el/menus/colors/auto/equalize(color-enhance, autostretch-hsv, normalize, c-astretch, white-balance).xml and b) xml/el/filters/animation/spinning-globe(burn-in, waves, optimize, playback, rippling).xml
with the same problem in the same position:
Traceback (most recent call last):
File "./tools/xml2po.py", line 191, in
main(sys.argv[1:])
File "./tools/xml2po.py", line 174, in main
xml2po_main.merge(mofile, filenames[0])
File "/home/d1-02/gimp-help-2/tools/xml2po/__init__.py", line 588, in merge
self.gt = gettext.GNUTranslations(mfile)
File "/usr/lib/python2.7/gettext.py", line 180, in __init__
self._parse(fp)
File "/usr/lib/python2.7/gettext.py", line 314, in _parse
plural = v[1].split('plural=')[1]
IndexError: list index out of range
and the corresponding files .xml are 0 bytes. 2. The and are reproduced as “ and &x201D; in the html files.
I'd appreciate any help (I don't have knowledges of programming).
RyōTa SimaMoto
2012-04-10 15:16:38 UTC (about 13 years ago)
The first problem probably might be caused the 'Plural-Forms:' line of the header information part of these PO file. Try running make validate-el after editing the line of filters/animation.po and menus/colors/auto.po as: -"Plural-Forms: nplurals=2; plurals=(n != 1)\n" +"Plural-Forms: nplurals=2; plural=(n != 1)\n"
The second issue is not gimp-docs specific; the contents of 'startquote' and 'endquote' are defined at share/xsl/docbook/common/el.xml file which is installed by docbook-xsl package.
2012/4/10, dmtrs32 :
main(sys.argv[1:])
self._parse(fp)
