Python plugin debugging and workflow
Python plugin debugging and workflow Jon Decker 03 Apr 11:01
  Python plugin debugging and workflow Joao S. O. Bueno 04 Apr 12:53
   Python plugin debugging and workflow Ragnar Brynjúlfsson 04 Apr 13:01
    Python plugin debugging and workflow Jon Decker 04 Apr 13:15
    Python plugin debugging and workflow Jernej Simončič 04 Apr 17:52
Jon Decker
2012-04-03 11:01:40 UTC (over 13 years ago)
Hello
I have a lot of work into my first large plugin. One thing that really slows my progress is the lack of any kind of debugging or work flow. For example, if I make a syntax error, the plugin will just silently fail, or fail to appear in the menu. I receive no erros or hints as to where the error occured. I normally have to commentoput code line-by-line and rerun the plugin until I find the offending line of code. I've wasted hours at a time finding small little bugs like this.
Is there a way to have gimp relay python errors?
I have also noticed that the python plugins will not run outside of gimp with the standard python interpreter (can't find the gimp imports).
Is there something I'm missing? Is this the workflow that everybody uses? Any hints or tips?
thanks!
Joao S. O. Bueno
2012-04-04 12:53:52 UTC (over 13 years ago)
On 3 April 2012 08:01, Jon Decker wrote:
Hello
to detect syntax errors, just try to run your plug-ina s a normal Python program -
Syntax errors will be flagged normally - i the program is well formed, it will fail with an import error
when trying to import gimp or gimpfu
As fro runtime erros, just watch the normal error output of GIMP on the terminal.
(the good news is taht for fixing these errors, you just have to re-run the plugin from inside GIMP<
no need to reinstall or relaod anything).
js ->
thanks!
gimp-developer-list@gnome.org
Ragnar Brynjúlfsson
2012-04-04 13:01:34 UTC (over 13 years ago)
I'm assuming Jon is working on Windows. On Linux you can just start gimp from a terminal and get all the output you need, but when I was porting a plug-in I wrote to Windows, there was no info in the command line, and I had to resort to printing stuff to the gimp error console. Anyone know how to do this on windows.
One solution is, of course, to just install Linux (on a physical or virtual machine) and do the development on that.
Ragnar
Hello
js ->
thanks!
Jon Decker
2012-04-04 13:15:08 UTC (over 13 years ago)
Thanks for the info guys.
Yes, I am already developing on Linux (I am a long time linux user, I haven't touched Windows since win98). I'll start launching Gimp from the terminal and watching for output there On Apr 4, 2012 9:01 AM, "Ragnar Brynjúlfsson" wrote:
Ragnar
Hello
For
or
rerun
at a
js ->
uses?
Any hints or tips?
thanks!
Jernej Simončič
2012-04-04 17:52:50 UTC (over 13 years ago)
The simple way is to run gimp with --verbose switch - that'll open a console window.
