bug with Overlay
15 of 15 messages available
bug with Overlay Paul Geraskin 03 Apr 22:17
  bug with Overlay gespertino@gmail.com 04 Apr 00:11
   bug with Overlay Paul Geraskin 04 Apr 08:54
    bug with Overlay Przemyslaw Golab 04 Apr 09:12
     bug with Overlay Paul Geraskin 04 Apr 09:22
      bug with Overlay Michael Natterer 04 Apr 14:03
       bug with Overlay Paul Geraskin 04 Apr 14:23
        bug with Overlay Alexandre Prokoudine 04 Apr 15:07
        bug with Overlay gespertino@gmail.com 04 Apr 15:09
         bug with Overlay Alexandre Prokoudine 04 Apr 15:29
         bug with Overlay Paul Geraskin 04 Apr 15:36
         bug with Overlay Paul Geraskin 04 Apr 17:05
     bug with Overlay Paul Geraskin 05 Apr 13:21
   bug with Overlay Paul Geraskin 04 Apr 09:11
   bug with Overlay Paul Geraskin 04 Apr 12:47
Paul Geraskin
2012-04-03 22:17:43 UTC (about 13 years ago)
2012-04-04 00:11:07 UTC (about 13 years ago)
bug with Overlay
2012/4/3 Paul Geraskin
Hi!
I found a bug with Overlay and Gegl:
I don't think it's a bug.
As far as I can tell, that's because the 3D program where you created your multilayered file does layer blending in linear space and GIMP with GEGL off does it in gamma-corrected space. When "use GEGL" is selected, GIMP does the layer blending in linear space too, then you get similar results in both applications. Some blending modes like overlay look very different in linear and non-linear space.
I'm not 100% sure, but it looks exactly like that.
Paul Geraskin
2012-04-04 08:54:34 UTC (about 13 years ago)
bug with Overlay
Also, the problem is only with Overlay Method. Multyply, Screen, Dodge, SoftLight, HardLight etc... works ok with Gegl and without Gegl. I showed it on the video.
So, the problem is only with Overlay.
Paul Geraskin
2012-04-04 09:11:52 UTC (about 13 years ago)
bug with Overlay
Here is my PSD Test file you can take:
http://dl.dropbox.com/u/26887202/123/3dcoat/goat.psd
Przemyslaw Golab
2012-04-04 09:12:45 UTC (about 13 years ago)
bug with Overlay
Note: Overlay in Legacy mode works exactly like Soft Light, if that helps.
Paul Geraskin
2012-04-04 09:22:30 UTC (about 13 years ago)
bug with Overlay
Thanks.
At present, I cannot use Overlay for my 3d production. This is the most usable method. I just want to know will you be able to fix it in Gimp 2.8? Overlay without Gegl should be like in Photoshop too.
Or is there any way to export/apply Gegl ColorManagement?
-- n-pigeon
Paul Geraskin
2012-04-04 12:47:11 UTC (about 13 years ago)
bug with Overlay
I also made my post to bugzilla:
https://bugzilla.gnome.org/show_bug.cgi?id=673501
Michael Natterer
2012-04-04 14:03:33 UTC (about 13 years ago)
bug with Overlay
On Wed, 2012-04-04 at 13:22 +0400, Paul Geraskin wrote:
Thanks.
On a general note, *nothing* in GIMP should be "like in Photoshop". Most of us don't have Photoshop, or even an operating system where it would run on, and it's not our goal to imitate anything.
Regards, --Mitch
-- n-pigeon
gimp-developer-list@gnome.org
Paul Geraskin
2012-04-04 14:23:22 UTC (about 13 years ago)
bug with Overlay
I have no photoshop too. I'm a Linux user. I use Gimp about 7 years for CG(Computer Graphics). But you can try VirtualBox(WinXP) and http://thepiratebay.se/torrent/4985377/Adobe_Photoshop_CS3_Portable for testing if you need it.
If we talk about CG, so there are some standards in many CG programs based on Photoshop. As I mentioned previously, you already made Overlay with Gegl. It works ok, but I cannot save to file (png/jpg/...) with Gegl color Management. And it's not possible to merge layers with Gegl color management too. As I mentioned it in video.
Is it possible to add saving to file with Gegl Color Management if "View->Use Gegl" is switched on?
Thanks.
Regards, --Mitch
2012-04-04 15:07:10 UTC (about 13 years ago)
bug with Overlay
Future v2.10 (currently goat-invasion branch) already saves XCF with GEGL's data structure.
2012-04-04 15:09:54 UTC (about 13 years ago)
bug with Overlay
2012/4/4 Paul Geraskin
I don't think it's appropriate to link to copies of commercial software here. This is not a warez forum.
It's also pointless. Developers aren't looking at Photoshop because they can't get a copy. They aren't because they don't want to. GIMP is not photoshop and there is no need to copy it.
That's not correct. Industry standard aren't "based on Photoshop". The results are similar because they use the same principles (high bit depth, compositing in linear space, color management). It's true that GIMP before GEGL was somewhat disconnected with some high end standards but that's planned to change when GIMP runs completely on GEGL.
Forget the rest, this looks like a reasonable feature request: "bake" the GEGL projection into the saved file. That would be nice and solve your problems, right?
2012-04-04 15:29:35 UTC (about 13 years ago)
bug with Overlay
2012/4/4 gespertino@gmail.com :
No matter how often you talk of Layer/New From Visible, people will still ignore it, right? ;)
Paul Geraskin
2012-04-04 15:36:55 UTC (about 13 years ago)
bug with Overlay
That's right! That's all I need. Photoshop will suck if you add this feature. :)
I just need to save all Layers with GEGL projection to jpg/png.
Paul Geraskin
2012-04-04 17:05:27 UTC (about 13 years ago)
bug with Overlay
OMG!
It works! Thank you all Guys!
"Layer->New From Visible" works pretty good. But I hope it will be supported by exporters too in future.
GOD BLESS GIMP DEVELOPERS!!!!
Paul Geraskin
2012-04-05 13:21:56 UTC (about 13 years ago)
bug with Overlay
I did a video tutorial how to use Gimp wit corrected Overlay.
http://www.gimptalk.com/index.php?/topic/52581-tutorial-gimp-overlay-mode-fix/
Thanks to all.
