What happened to daily digests in Gimp mailing lists?
What happened to daily digests in Gimp mailing lists? Howard Caluma 03 Apr 00:40
  What happened to daily digests in Gimp mailing lists? David Gowers (kampu) 03 Apr 01:49
   What happened to daily digests in Gimp mailing lists? Howard Caluma 04 Apr 09:26
Howard Caluma
2012-04-03 00:40:59 UTC (about 13 years ago)
Is there a way to make the mails sent to me appear as daily digest? I like the organization of topics with daily digest because they are listed first to give an overview and then packed in a single mail. Although this makes the mails very long, I still find reading them easy and enjoyable. The mails I receive contain only one topic each. The mails are short and filtering mails I want to keep is easy so it is also good. Another problem is that some replies are deleted, separated or not shown to me but is only received by author of the topic. Is it in the reply and reply to all? I am also subscribed to Gimp user list and have same concern.
2012-04-03 01:49:21 UTC (about 13 years ago)
Hi Howard,
Yes. It's in your subscription options in the mailman web interface.
What you mean is not clear, but, yes, if you happen to hit reply rather than reply to all, then the email goes only to the person you are replying to and not to the mailing list.
Howard Caluma
2012-04-04 09:26:28 UTC (about 13 years ago)
Thank you very much David! I had no idea how Digest Mode was turned off but its already okay!
On Tue, Apr 3, 2012 at 9:49 AM, David Gowers (kampu) wrote:
Hi Howard,
received
