wget plugin
wget plugin Alexandre Prokoudine 01 Apr 08:56
  wget plugin Mukund Sivaraman 01 Apr 09:31
   wget plugin Mikael Magnusson 01 Apr 11:45
2012-04-01 08:56:54 UTC (about 13 years ago)
wget plugin
I've been wondering for a while why the plug-in for fetching an image from network location always shows its messages in English, so I ended up looking into the code...
plug-ins/file-uri/uri-backend-wget.c has this:
g_setenv ("LANGUAGE", "C", TRUE); g_setenv ("LC_ALL", "C", TRUE); g_setenv ("LANG", "C", TRUE);
And then translatable messages follow.
So the plug-in doesn't even give those messages a chance to show up as translated, while providing false hope :)
Is there a reason for such a cruelty? :)
Mukund Sivaraman
2012-04-01 09:31:30 UTC (about 13 years ago)
wget plugin
Hi Alexandre
The plug-in parses the output of wget to gather the status of what happened. So it needs the output of wget in the C locale, so it has just 1 variant to compare.
The wget plug-in is a fallback option. Maybe you can use GVFS or libcurl.
Mukund
Mikael Magnusson
2012-04-01 11:45:45 UTC (about 13 years ago)
wget plugin
On 1 April 2012 11:31, Mukund Sivaraman wrote:
Hi Alexandre
It does the setenv after forking, so it shouldn't affect messages getting translated in the parent process:
else if (pid == 0) {
gchar timeout_str[16];
close (p[0]); close (2);
dup (p[1]);
close (p[1]);
/* produce deterministic output */ g_setenv ("LANGUAGE", "C", TRUE); g_setenv ("LC_ALL", "C", TRUE); g_setenv ("LANG", "C", TRUE);
g_snprintf (timeout_str, sizeof (timeout_str), "%d", TIMEOUT);
execlp ("wget", "wget", "-v", "-e", "server-response=off", "--progress=dot", "-T", timeout_str, uri, "-O", tmpname, NULL); _exit (127);
