i18n enabled for GEGL
i18n enabled for GEGL Michael Muré 31 Mar 10:08
  i18n enabled for GEGL Nguyen Thai Ngoc Duy 31 Mar 10:34
i18n enabled for GEGL Michael Muré 31 Mar 10:45
Michael Muré
2012-03-31 10:08:41 UTC (about 13 years ago)
GEGL, the graph based image processing framework and future core of GIMP is now i18n enabled in GIT master.
Can you add it as a new module in http://l10n.gnome.org/ ?
Please let me know if anything should be done.
Thank you,
Michael Muré
2012-03-31 10:34:02 UTC (about 13 years ago)
Please fix the problems reported in
http://l10n.gnome.org/module/gegl/
especially
intltool-update -g 'gegl' -p ./../operations/common/display.c:23: warning: Empty msgid. It is reserved by GNU gettext:
gettext("") returns the header entry with
meta information, not the empty string.
xgettext: error while opening "./../operations/common/plasma.c" for reading: No such file or directory
ERROR: xgettext failed to generate PO template file. Please consult error message above if there is any.
Michael Muré
2012-03-31 10:45:15 UTC (about 13 years ago)
It's done. Thank you.
2012/3/31 Nguyen Thai Ngoc Duy
is
especially
ERROR: xgettext failed to generate PO template file. Please consult error message above if there is any. --
Duy
