Help with gimpplugin module (Jon Decker)
Help with gimpplugin module (Jon Decker) lloyd konneker 10 Mar 16:27
lloyd konneker
2012-03-10 16:27:01 UTC (about 13 years ago)
Why do you need gimpplugin? Very few people really need gimpplugin, thus the documentation is adequate? A path that no one is taking is not easy to follow.
You can create a plugin that is not related to a particular image and that has an unrestricted GUI, using PyGTK, and even using Glade. See for example: https://github.com/bootchk/gimpscripter
registry.gimp.org might be a better forum for plugin help.
