make status problem
| make status problem | Marco Ciampa | 09 Mar 18:07 |
| make status problem | Ulf-D. Ehlert | 09 Mar 19:28 |
| make status problem | Marco Ciampa | 10 Mar 13:45 |
| make status problem | Ulf-D. Ehlert | 10 Mar 19:46 |
| make status problem | Marco Ciampa | 10 Mar 20:26 |
| make status problem | Ulf-D. Ehlert | 10 Mar 21:19 |
| make status problem | Marco Ciampa | 10 Mar 22:21 |
| make status problem | Marco Ciampa | 10 Mar 22:33 |
| make status problem | Ulf-D. Ehlert | 12 Mar 20:53 |
| Comments in POT files | Julien Hardelin | 11 Mar 20:57 |
| Comments in POT files | RyōTa SimaMoto | 12 Mar 01:57 |
| Comments in POT files | Julien Hardelin | 12 Mar 06:43 |
| make validate problem | Julien Hardelin | 15 Mar 20:26 |
| make validate problem | Ulf-D. Ehlert | 16 Mar 11:28 |
| make validate problem | Julien Hardelin | 16 Mar 13:52 |
| make validate problem | Ulf-D. Ehlert | 16 Mar 19:22 |
| make validate problem | Julien Hardelin | 16 Mar 20:47 |
make status problem
marco@lap2-ciampix:~/git-gnome/gimp-help-2$ make validate-it
[SRC] src/preface/authors.xml
it: no errors.
marco@lap2-ciampix:~/git-gnome/gimp-help-2$ make html-it
Cleaning up 'it' po files ...
Cleaning up 'it' xml files ...
marco@lap2-ciampix:~/git-gnome/gimp-help-2$ make status-it
ERROR matching msgfmt output 'po/it/appendix.po 216107 679 messaggi tradotti.
make: *** [po-status-it] Errore 29
??? Any hint?
make status problem
ERROR matching msgfmt output 'po/it/appendix.po 216107 679 messaggi tradotti. '
Maybe "po/it/concepts.po" (the next file in the list of pofiles) is
broken; try e.g.
msgfmt --statistics po/it/concepts.po >/dev/null
or
msgfmt --check po/it/concepts.po
Ulf
Wer immer wieder Abweichungen vom Evangelium beklagt, verkennt, da Jesus und seine Jnger theologisch noch in den Kinderschuhen steckten und erst viel spter die Ppste deutlich zu sagen vermochten, was der Erlser und seine Apostel eigentlich gemeint, was sie vielleicht nicht so gesagt oder ganz anders gesagt oder berhaupt nicht gesagt haben, weil sie es noch nicht besser oder gar nicht sagen konnten, doch sicher sagen wollten und auch gesagt htten, wren sie schon so schlau gewesen wie die Ppste. -- Karlheinz Deschner _______________________________________________ gimp-docs-list mailing list gimp-docs-list@gnome.org http://mail.gnome.org/mailman/listinfo/gimp-docs-list
make status problem
make: *** [po-status-it] Errore 29Maybe "po/it/concepts.po" (the next file in the list of pofiles) is broken; try e.g.
msgfmt --statistics po/it/concepts.po >/dev/null or
msgfmt --check po/it/concepts.poUlf
$msgfmt --statistics po/it/concepts.po >/dev/null 982 messaggi tradotti.
(no error)
(no message = no error)
make status-it
(error still there...)
make status problem
(no error)
make status-it [SRC] src/preface/authors.xml
Then try it with all po files you have edited -- or even with all
po files:
find po/it -type f | \
while read f; do echo $f `msgfmt --check $f`; done
Ulf
Wer ber den Berg ist - geht abwrts. -- Karlheinz Deschner _______________________________________________ gimp-docs-list mailing list gimp-docs-list@gnome.org http://mail.gnome.org/mailman/listinfo/gimp-docs-list
make status problem
(no error)
make: *** [po-status-it] Errore 29Then try it with all po files you have edited -- or even with all po files:
while read f; do echo $f `msgfmt --check $f`; doneUlf
Done. No errors. That error number 29 ... who is firing it? Make? Then why and what it means?
make status problem
On Sat, Mar 10, 2012 at 09:26:53PM +0100, Marco Ciampa wrote: [...]
Good questions. I don't know why the error number is 29, but the error message came from the Perl script that generates the status report. So your pofiles are ok, it was a bug (sorry, I should have noticed it sooner...).
Try the attached patch - hope it works.
Ulf
Wer über den Berg ist - geht abwärts. -- Karlheinz Deschner
make status problem
It worked perfectly. I think you can push it. As usual, many thanks.
make status problem
BTW: has this any sense: tools/create_changelog.py ?
How to add comments in xml files so that they appear in POT files (and then in Po files)?
Julien
Hi, Julien
Surround your message by a pair of comment tags (i.e. ) and put it just before each the corresponding or another content tag. The way of "NOTE TO TRANSLATORS:" message at src/appendix/gfdl.xml may give some hint for you. But I suggest a sample on a snippet of toolbox/gegl-operation.xml:
If the options of the selected GEGL operation
are not self-explanatory (guess what's the purpose of the
color operation's Color option)
you can look for a corresponding non-GEGL tool.
For example, the Fractal
Explorer filter may have the same or similar options as the
fractal-explorer operation.
Or you can make use of the nice realtime preview feature and just
then this entry of PO file might become:
+#. NOTE:
+#. For non-English users, inserting an additional information
+#. after the fourth line "non-GEGL tool" may
+#. help them like this:
+#. ... tool that can be seen on the
+#. English version
+#. of GIMP
+#: src/toolbox/gegl-operation.xml:129(para)
msgid ""
"If the options of the selected GEGL operation are not "
"self-explanatory (guess what's the purpose of the color "
"operation's Color option) you can look for a corresponding "
"non-GEGL tool. For example, the :
Julien
Oh yes!
Thank you
make status problem
Looks like this is a script (plugin?) to edit CVS or SVN Changelogs with Vim. So you can safely remove it IMO. Roman is far away... ;)
Ulf
When I create a link to a new file (which has the ID), I get the error : /IDREF attribute linkend references an unknown ID/
I tried and tried again in multiple ways and I have always this error.
Is there a bug in make validate-en?
Julien Hardelin
Did you really include this new file somewhere?
Ulf
Wenn die Affen katholisch wrden und der Kirche ntzten, ich bin sicher, sie sprchen einige heilig. - Aber haben wir denn diesen Fall nicht schon? -- Karlheinz Deschner _______________________________________________ gimp-docs-list mailing list gimp-docs-list@gnome.org http://mail.gnome.org/mailman/listinfo/gimp-docs-list
A.simple example to test is attached (please save your gimp.xml before installing).
Your "gimp.xml" includes "test-id.xml", but not "test-identif.xml",
so your resulting document contains
Teste ID
but *not*
and you are indeed referencing an unknown id.
Ulf
PS: You should always start a new thread for every new topic.
Wer beleidigt, braucht nicht unrecht haben; es gibt Kpfe, denen man erst Verstand liefern mte, um sie berzeugen zu knnen. -- Karlheinz Deschner _______________________________________________ gimp-docs-list mailing list gimp-docs-list@gnome.org http://mail.gnome.org/mailman/listinfo/gimp-docs-list
Ach so! I see.
I have not used xml for a long time and I have forgoten many things.
Thank you very much.
Julien
Your "gimp.xml" includes "test-id.xml", but not "test-identif.xml", so your resulting document contains
Teste ID
but *not*
