Retouch 'push' tool?
Retouch 'push' tool? Jeremy Morton 02 Mar 19:46
  Retouch 'push' tool? Liam R E Quin 02 Mar 20:32
Retouch 'push' tool? Jeremy Morton 03 Mar 07:53
  Retouch 'push' tool? David Gowers (kampu) 03 Mar 07:58
Jeremy Morton
2012-03-02 19:46:10 UTC (about 13 years ago)
Does GIMP have an equivalent to Paint Shop Pro's retouch 'push' tool? It's similar to but not the same as the smudge tool.
Liam R E Quin
2012-03-02 20:32:26 UTC (about 13 years ago)
Rather than assuming people are familiar with a particular proprietary piece of software, it works best to say what you want to do and why.
Also check out the tool options for the smudge tool, in case they help; if not, say more exactly what the difference might be. I've actually used PaintShop Pro but it was about 10 or 15 years ago I think.
Liam
Jeremy Morton
2012-03-03 07:53:22 UTC (about 13 years ago)
Paint Shop Pro's documentation of it says:
"Similar to Smudge, but does not pick up any new color."
So it's basically maintaining the colors of the area you initially clicked on when you started the click-drag. I don't see how IWarp is equivalent, because it operates on a whole image. Push is, well, similar to smudge - you drag the cursor around to manipulate the image.
2012-03-03 07:58:37 UTC (about 13 years ago)
Smudge with Rate set to 100.
