Postscript 64-bit
14 of 14 messages available
Postscript 64-bit Partha Bagchi 20 Feb 23:29
  Postscript 64-bit Mukund Sivaraman 22 Feb 13:56
   Postscript 64-bit Partha Bagchi 27 Feb 10:46
    Postscript 64-bit Mukund Sivaraman 27 Feb 10:57
     Postscript 64-bit Partha Bagchi 11 Mar 21:37
      Postscript 64-bit Jernej Simončič 11 Mar 22:02
       Postscript 64-bit Partha Bagchi 11 Mar 22:12
  Postscript 64-bit Alexandre Prokoudine 22 Feb 23:48
   Postscript 64-bit Mukund Sivaraman 22 Feb 23:51
    Postscript 64-bit Alexandre Prokoudine 23 Feb 00:03
     status of gimp 2.8 Hamilton Fischer 26 Feb 19:17
      status of gimp 2.8 Alexandre Prokoudine 26 Feb 19:28
       status of gimp 2.8 Sonic Spuds 03 Mar 17:56
        status of gimp 2.8 C55inator 04 Mar 23:25
Partha Bagchi
2012-02-20 23:29:11 UTC (almost 13 years ago)
Postscript 64-bit
Hi Mukund,
Thanks for making it so that gimp build requires one less application to package! It is working flawlessly in Windows 32-bit. :)
I am having trouble on 64-bit. There is not output and the only error message I have to give you is:
____________Error Message____________ Opening 'C:\Users\partha\Pictures\Images\PostScript Examples\tiger.eps' failed:
Could not interpret Postscript file 'C:\Users\partha\Pictures\Images\PostScript Examples\tiger.eps' ____________End Error________________
Any suggestions would be most helpful
Thanks! Partha
Mukund Sivaraman
2012-02-22 13:56:35 UTC (almost 13 years ago)
Postscript 64-bit
Hi Partha
On Mon, Feb 20, 2012 at 06:29:11PM -0500, Partha Bagchi wrote:
Hi Mukund,
I don't know what this issue might be as it is on Windows and I don't have a Windows environment handy. Maybe you can talk to ender about it. Even he will have to bundle Ghostscript in his Windows installer.
Kind regards,
Mukund
2012-02-22 23:48:30 UTC (almost 13 years ago)
Postscript 64-bit
On Tue, Feb 21, 2012 at 3:29 AM, Partha Bagchi wrote:
Hi Mukund,
Interesting, a 2.6.12 user just reported this:
"Hi! I've found really bad error in 2.6.12 - I can't import pdf files properly. Only vector elements (e.g. texts) can be opened, raster images are missing or left as black rectangles. 2.6.11 works fine. (Win7 64bit)"
Mukund Sivaraman
2012-02-22 23:51:28 UTC (almost 13 years ago)
Postscript 64-bit
Hi Mukund,
The change Partha mentions is only in the master branch.
Kind regards,
Mukund
2012-02-23 00:03:34 UTC (almost 13 years ago)
Postscript 64-bit
No! Really? :)
Hamilton Fischer
2012-02-26 19:17:21 UTC (almost 13 years ago)
status of gimp 2.8
I don't want to be pushy, but I'm curious about the status of work on gimp 2.8. Just curious.
noobermin
2012-02-26 19:28:43 UTC (almost 13 years ago)
status of gimp 2.8
It's a work in progress, final stage.
Partha Bagchi
2012-02-27 10:46:45 UTC (almost 13 years ago)
Postscript 64-bit
On Wed, Feb 22, 2012 at 8:56 AM, Mukund Sivaraman wrote:
Hi Partha
Hi Mukund,
Mukund Sivaraman
2012-02-27 10:57:39 UTC (almost 13 years ago)
Postscript 64-bit
Hi Partha
On Mon, Feb 27, 2012 at 05:46:45AM -0500, Partha Bagchi wrote:
Thanks for you response Mukund. I will continue to investigate by isolating the iapi code and running it separately to determine why it does not work on 64-bit Windows. Does it work on 64-bit Linux?
Sure it does :)
Finally, Ender, can you help or are you aware of this issue?
Thanks! Partha
Kind regards,
Mukund
Sonic Spuds
2012-03-03 17:56:10 UTC (almost 13 years ago)
status of gimp 2.8
Is there anything that us non-programmers can do to speed the process? (Try to do a splash screen contest etc.)
-Sonic
On Sun, Feb 26, 2012 at 1:28 PM, Alexandre Prokoudine < alexandre.prokoudine@gmail.com> wrote:
gimp
2.8. Just curious.
gimp-developer-list@gnome.org
C55inator
2012-03-04 23:25:50 UTC (almost 13 years ago)
status of gimp 2.8
Also wondering :) I'm an artist who does all work in GIMP, no programming experience though. Is there any way for us designers to help contribute to the development without coding [icons, UI, etc]? Or are donations the best way to help?
-Sonic
On Sun, Feb 26, 2012 at 1:28 PM, Alexandre Prokoudine wrote: On Sun, Feb 26, 2012 at 11:17 PM, Hamilton Fischer wrote:
Partha Bagchi
2012-03-11 21:37:24 UTC (almost 13 years ago)
Postscript 64-bit
On Mon, Feb 27, 2012 at 5:57 AM, Mukund Sivaraman wrote:
Hi Partha
Sure it does :)
I knew you would say that. :)
I didn't see any replies from him here. So perhaps he is busy.
Thanks!
Partha
Kind regards,
Mukund
Anyway, I made some more progress on this. libgs-8.dll (Ghostscript 8.47) that I am using is built with libtiff 4.0.1. This was the main culprit. When I use tiff 4.0.1, Gimp will no longer open tiff files complaining that it was unable to read the header. This is true (for me) on both Windows 32 and 64 bit. So, I rebuilt tiff 3.9.4, which created libtiff-3.dll and Gimp can open tiff files now. However, it breaks Ghostscript and so I reverted your changes and went back to loading an external program to load PS files.
I wonder why tiff 4.0.1 is failing on my builds. Has anyone tested tiff 4.0.1 on a Linux machine to confirm this?
Thanks for all your help Mukund. It really helped me with this problem.
Partha
Jernej Simončič
2012-03-11 22:02:19 UTC (almost 13 years ago)
Postscript 64-bit
I haven't tried building with ghostscript yet.
This seems to be a Windows-specific problem. I've got GIMP 2.6.12 built against libtiff-5.dll (ver. 4.0.0), and it doesn't load any tiff files, while GIMP 2.6.12 on Linux built against libtiff.so.5.0.5 (version 4.0.0-r1, gentoo) works fine.
Partha Bagchi
2012-03-11 22:12:59 UTC (almost 13 years ago)
Postscript 64-bit
2012/3/11 Jernej Simončič :
Thanks for the confirmation, Ender. Looks like I will stay with 3.9.4 then which is working fine on Windows (64 or 32). Gimp will not load a tiff file with 4.0.1 on Windows.
Partha
< Jernej Simončič ><><><><>< http://eternallybored.org/ >
That which we call sin in others is experiment for us.       -- Emerson's Insight
