Gimp Plugin Registry for openSUSE
Gimp Plugin Registry for openSUSE Swapnil Bhartiya 16 Feb 13:54
  Gimp Plugin Registry for openSUSE Owen 16 Feb 19:41
   Gimp Plugin Registry for openSUSE Swapnil Bhartiya 18 Feb 21:25
    Gimp Plugin Registry for openSUSE Owen 18 Feb 22:37
Swapnil Bhartiya
2012-02-16 13:54:06 UTC (about 13 years ago)
I have started using openSUSE but I can't find the GIMP Plugin Registry in the repos. How do I install these in openSUSE 12.1. I was able to install it from Synaptic in Ubuntu earlier.
Swapnil Bhartiya
Owen
2012-02-16 19:41:27 UTC (about 13 years ago)
The gimp plug in registry is at http://registry.gimp.org/
There are 1000s of scripts, what Ubuntu gave you was just a few selected scripts gathered by a packager for Ubuntu
Your distro may provide some plugins, or maybe not.
You are better off installing your own from the registry.
1. Download a script of your choosing 2. Place it in your ~./gimp-2.6/scripts directory
If it is a python script, place it in ~./gimp-2.6/plug-ins and make it excutable
HTH
There maybe other gotchas, but come back and ask if you have problems, probably best on the gimp users list, not this one. Also you can try IRC, freenode #gimp
Owen
Swapnil Bhartiya
2012-02-18 21:25:50 UTC (about 13 years ago)
HTH
Thanks Owen,
That helped. Started using it :-)
Best Swapnil
Owen
2012-02-18 22:37:41 UTC (about 13 years ago)
Thanks Owen,
Best Swapnil
It just occurred to me that what is normally packaged by Ubuntu and probably Fedora, is the FX Foundary package. http://gimpfx-foundry.sourceforge.net/
I think it an extremely handy package.
Also you may wish to look at; http://sourceforge.net/directory/os:linux/freshness:recently-updated/?q=gimp
Also there is the GMIC plugin, excellent. http://gmic.sourceforge.net/
-- Owen
