Problem using introspection
Problem using introspection Patrick Horgan 13 Feb 01:55
Patrick Horgan
2012-02-13 01:55:09 UTC (about 13 years ago)
Building babl from git on an ubuntu box with introspection turned on (but otherwise default configuration), I get an error, although it builds fine without it. Of course then gegl from git doesn't want to build with introspection on either. Does anyone know what this error is trying to tell me?
CCLD libbabl-0.1.la /usr/bin/g-ir-scanner -v --namespace Babl --nsversion=0.1 \ --add-include-path=. --add-include-path=. \ --library=babl-0.1 \
--libtool="/bin/bash ../libtool" \ --output Babl-0.1.gir \
-DBABL_IS_BEING_COMPILED \ -I.. \
-I.. \
./babl-macros.h ./babl-types.h ./babl.h \ ./babl-version.h \
./babl.c ./babl-component.c ./babl-conversion.c ./babl-core.c ./babl-db.c ./babl-extension.c ./babl-fish-path.c ./babl-fish-reference.c ./babl-fish-simple.c ./babl-fish-stats.c ./babl-fish.c ./babl-format.c ./babl-hash-table.c ./babl-image.c ./babl-internal.c ./babl-introspect.c ./babl-list.c ./babl-memory.c ./babl-model.c ./babl-mutex.c ./babl-sampling.c ./babl-sanity.c ./babl-type.c ./babl-util.c ./babl-cpuaccel.c ./babl-version.c Must specify package names on the command line g-ir-scanner: compile: gcc -Wall -pthread -I/usr/local/include/glib-2.0 -I/usr/local/lib/glib-2.0/include -I.. -I.. -c -o /usr/local/babl/babl/tmp-introspectb_aby8/Babl-0.1.o /usr/local/babl/babl/tmp-introspectb_aby8/Babl-0.1.c /usr/local/babl/babl/tmp-introspectb_aby8/Babl-0.1.c: In function ‘main’: /usr/local/babl/babl/tmp-introspectb_aby8/Babl-0.1.c:577:3: warning: ‘g_thread_init’ is deprecated (declared at /usr/local/include/glib-2.0/glib/deprecated/gthread.h:259) [-Wdeprecated-declarations] g-ir-scanner: link: /bin/bash ../libtool --mode=link --tag=CC gcc -o /usr/local/babl/babl/tmp-introspectb_aby8/Babl-0.1 -export-dynamic -L. -lbabl-0.1 -pthread -L/usr/local/lib -lgio-2.0 -lgobject-2.0 -lgthread-2.0 -lrt -lglib-2.0 /usr/local/babl/babl/tmp-introspectb_aby8/Babl-0.1.o libtool: link: gcc -o /usr/local/babl/babl/tmp-introspectb_aby8/.libs/Babl-0.1 -pthread /usr/local/babl/babl/tmp-introspectb_aby8/Babl-0.1.o -Wl,--export-dynamic -L. /usr/local/babl/babl/.libs/libbabl-0.1.so -L/usr/local/lib /usr/local/lib/libgio-2.0.so /usr/local/lib/libgobject-2.0.so /usr/local/lib/libgthread-2.0.so -lrt /usr/local/lib/libglib-2.0.so -pthread ERROR: can't resolve libraries to shared libraries: babl-0.1 make[3]: *** [Babl-0.1.gir] Error 1
make[3]: Leaving directory `/usr/local/babl/babl' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `/usr/local/babl/babl' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/usr/local/babl' make: *** [all] Error 2
