QuickMask vs. Show Layer Mask
QuickMask vs. Show Layer Mask Richard Gitschlag 09 Feb 18:26
  QuickMask vs. Show Layer Mask gespertino@gmail.com 11 Feb 15:45
   QuickMask vs. Show Layer Mask gespertino@gmail.com 11 Feb 15:55
   QuickMask vs. Show Layer Mask Richard Gitschlag 11 Feb 17:50
Richard Gitschlag
2012-02-09 18:26:43 UTC (about 13 years ago)
I know, these two tools serve two very different purposes; I'm not worried about that. Instead, I'm wondering about the manner in which each mask is displayed....
Can the QuickMask tool be tweaked to allow configuring two display colors/opacities - one for the "unselected" end and another for "selected" end of the channel? Currently (well, 2.6.12 anyway) the QuickMask essentially displays as a color-to-transparent gradient map on top of your image. Which works, but a FG-to-BG type gradient would be more flexible. You'd still be able to swap which color corresponds to which end, and you could easily duplicate the current behavior by configuring one of the mask colors for 0% opacity. Which means that the QuickMask's popup menu could, for example, look like this:
- Toggle QuickMask -----
- Selected color/opacity...
- Unselected color/opacity...
- Swap colors
Contrast "Show Layer Mask", which overlays a 100% opaque black-to-white gradient and whose colors/opacity (as of 2.6.12) cannot be configured. Can that be made configurable? Sure, the 100% solid gradient is useful, but there've been a few cases where I would've liked a less-than-opaque value (say, 80%) so I can still see some hint of the layer underneath the mask.
2012-02-11 15:45:08 UTC (about 13 years ago)
2012/2/9 Richard Gitschlag
I think the idea behind quick mask is to give a glimpse of what gets masked out with a selection. The quick mask color covers the transparent areas, leaving the solid pixels visible or vice-versa. Having a custom color/opacity for one end of the quick mask is all we need, and it's already available (by right-clicking the quick mask icon when it's active).
Quick mask does what it advertises: applies a quick, temporary mask based on the selection.
To my understanding, the layer mask is the layer's alpha channel, and I'm fine with it being a grayscale image when you display it. It's not a "quick mask" but a real mask, making pixels actually transparent or opaque, so I get the final result when it's active. Changing its color goes against what most of us understand as an alpha channel (a grayscale channel used to set the opacity of RGB pixels) Changing its opacity... I don't know. Honestly, I never felt the need of this, but I understand the point.
I use quick mask when I need to see through the mask and use a layer mask when I think the selection is ok and I need to see the final composite output.
Maybe adding an opacity selector to the layer mask view would be useful in certain situations, but I guess that since it's so specific and we have the quickmask for that nobody will really miss it if it isn't there.
2012-02-11 15:55:29 UTC (about 13 years ago)
Here's an idea:
What about a toggle to turn layer masks temporarily to quick masks and back?
Richard Gitschlag
2012-02-11 17:50:23 UTC (about 13 years ago)
Date: Sat, 11 Feb 2012 12:45:08 -0300 Subject: Re: [Gimp-developer] QuickMask vs. Show Layer Mask To: strata_ranger@hotmail.com
CC: gimp-developer-list@gnome.org
Quick mask does what it advertises: applies a quick, temporary mask based on the selection. --------------
Layer Masks are essentially a secondary alpha channel which you can edit using standard paint tools (otherwise, only the eraser tool operates directly on a layer's alpha; other tools depend on your blending mode), and they are tied one per layer.
QuickMask displays and allows you to see and edit GIMP's selection mask itself, also using standard paint tools. It is one per image canvas, independent of any layers and their stack or blending modes.
Of course the visibility of the QuickMask on what masking color you are using vs. what colors are already in your image -- a red mask color isn't going to help if you have significant reds already in your image, say, but that's why the color is configurable. However, if your image has a wide swath of colors, you may end up having to reconfigure the mask color several times depending on what portion you're working with at the time. On the other hand, if both extremes of QuickMask's range had configurable colors, this would lessen the need to do that.
And just to repeat, this idea would still support the existing behavior as either end of the range could be set fully transparent, depending on your individual process. (As a small aside, "good enough" does not mean "impossible to improve".)
