A file format to store process flow and original image untouched
A file format to store process flow and original image untouched wwp 03 Feb 19:48
  A file format to store process flow and original image untouched Alexandre Prokoudine 03 Feb 19:57
   A file format to store process flow and original image untouched wwp 03 Feb 20:04
  A file format to store process flow and original image untouched Bogdan Szczurek 05 Feb 00:11
wwp
2012-02-03 19:48:44 UTC (about 13 years ago)
Hello there!
I wonder if there's such a storage format, that is, or will (or would eventually) be supported by Gimp?
The idea is to get the process flow (modifications done to an image) stored to disk, allowing to undo/redo even after reopening the Gimp later, eventually reuse (parts of) the process flow and apply it to another image, etc.. I don't care if the process flow is stored with the original file in the same storage unit or separately.
Anyway.. some comments?
wwp
2012-02-03 19:57:24 UTC (about 13 years ago)
On Fri, Feb 3, 2012 at 11:48 PM, wwp wrote:
Hello there!
It's certainly doable. There is some free software like Ardour and darktable that allows undo/redo across sessions.
We haven't really discussed XCF2 much, so I think it would be fair to say that this is an open question. At some point we need to sit down and write a functional spec.
wwp
2012-02-03 20:04:46 UTC (about 13 years ago)
Hello Alexandre,
Hello there!
I presume it's not the first time such topic is raised here. I'm glad to see that it's an open question, I look forward to see further discussions!
wwp
Bogdan Szczurek
2012-02-05 00:11:13 UTC (about 13 years ago)
It smells a bit like node editing. It (kind of) showed up recently:
I can envision a work-space where you don't really have a layer toolbar open, but a node editor (with backdrop/main image if you need it) which you can scale/re-position, and do all your GEGL operations and magic with nodes, and be back to your main image/paint/edit window with the click of a shortcut.
I'd take it a bit futher: most frequently used node sequences grouped together in another nodes, to save, reuse and share with others.
Is it close enough to what is on your mind? I hope so, because I love that idea :).
My best!
thebodzio
