how to build the help files from existing html ?
how to build the help files from existing html ? Cristian Secară 31 Jan 17:06
  how to build the help files from existing html ? Ulf-D. Ehlert 31 Jan 17:51
Cristian Secară
2012-01-31 17:06:44 UTC (about 13 years ago)
În data de Tue, 4 Aug 2009 20:30:48 +0200, Ulf-D. Ehlert a scris:
The script we used when migrating to gettext-based documentation failed to extract, save, and reuse the glossary translations, I did never find out why. :-(
From this older post I understand that the documentation is now in gettext format (?) and that there is/was an utility to convert an existing html text to gettext (?).
Where can I find more details about this ?
There is someone who has translated the 2.6.x in Romanian as html http://gimp.e3.ro/
(less the translated snapshots)
He is now ready to update the text to suit 2.8. What is the way he must go on ?
Cristi
Ulf-D. Ehlert
2012-01-31 17:51:08 UTC (about 13 years ago)
No. If I remember correctly, that script converted our multi-language XML-files to several single-language XML-files of exactly the same structure, e.g.
old-doc.xml -----------
etc.
was converted to
en/new-doc.xml xx/new-doc.xml yy/new-doc.xml etc. -------------- -------------- --------------
and then these XML-files were converted to po-files.
Hmm, no idea right now... :-(
Ulf
