Help Documentation - Gimp Scripting
Help Documentation - Gimp Scripting Stephen Kiel 23 Jan 15:51
  Help Documentation - Gimp Scripting Kolbjørn Stuestøl 24 Jan 11:08
   Help Documentation - Gimp Scripting Vitaly Lomov 24 Jan 13:41
    Help Documentation - Gimp Scripting Julien Hardelin 24 Jan 20:49
     Help Documentation - Gimp Scripting Alexandre Prokoudine 25 Jan 13:41
      Help Documentation - Gimp Scripting Julien Hardelin 25 Jan 18:02
Stephen Kiel
2012-01-23 15:51:05 UTC (about 13 years ago)
I really appreciate the help documentation and the Gimp application in general. I thought it would be good for me to try to give something back. I focused on something that I struggled with, scripting with script-fu. I found that a lot of the help didn't quite get me to where I wanted to go. I thought about how I would improve the documentation to tell the story a better, and I felt that for me it was easier to just start with a clean sheet and lay it out.
I would like to offer my take on a Gimp Scripting tutorial for use as part of the Gimp documentation. You may use all of, part of, or none of it as you see fit. It is my hope that this can benefit others, but I have no other forum or place to post this tutorial. You or we can make what ever modifications to the code examples or text to make the explanation clearer or add any copyright required for release with Gimp.
The tutorial is under my spideroak share at: https://spideroak.com/browse/share/Stephen_Kiel_Pictures/tutorial The "RoomKey" is tutorial
The files in this share are:
.: GimpScriptingTutorial.docx
GimpScriptingTutorial.pdf
Images
scripts
Thumbs.db
./Images:
Thumbs.db
./scripts: configscripts
README.txt
roys-lum-separate.scm
roys-max-local-contrast.scm
script-fu-chroma-mask.scm
script-fu-combo-baselayers.scm
script-fu-combo-contrast-separate.scm script-fu-combo-prep.scm
script-fu-delete-dummylayer.scm
script-fu-display-asigned-parasites.scm script-fu-examples.scm
script-fu-flowzilla.scm
script-fu-get-named-drawable.scm
script-fu-grid.scm
script-fu-grow-canvas.scm
script-fu-jpg-to-xcf.scm
script-fu-list-index-from-name.scm
script-fu-make-two-layers.scm
script-fu-mark-autoupdate.scm
script-fu-mark-noautoupdate.scm
script-fu-para-note.scm
script-fu-para-tat-layer.scm
script-fu-scale-image.scm
script-fu-tat-origlayer.scm
script-fu-update-image.scm
script-fu-wrap-local-contrast.scm
script-fu-wrap-lum-separate.scm
script-fu-xcf-to-jpg.scm
./scripts/configscripts: sf-config-layerdef.scm
sf-config-paranote.scm
If you choose not to use any of the tutorial that I wrote, let me know at your convenience so I can take down the share.
Thanks for putting together a great application.
Stephen Kiel
Kolbjørn Stuestøl
2012-01-24 11:08:08 UTC (about 13 years ago)
I am impressed. Although I only have read the tutorials without trying to write the scripts. The tutorials are well written. The examples will be of good use to many GIMP users I think.
I think this tutorial should be accessible in some way to the users taking interests in using scrips. Perhaps this tutorial is too long to be incorporated as a part of the documentation. May be a cropped version with links to full version would be a solution? I assume that the script functions will be available and unchanged in the v 2.8.
Somebody take the challenge and writes the tutorials in "GIMP documentation style"?
Kolbjoern
Den 23.01.2012 16:51, skreiv Stephen Kiel:
Vitaly Lomov
2012-01-24 13:41:01 UTC (about 13 years ago)
I liked the PDF version, nice structure. Assuming the functions are the same, etc., why can't be incorporate it? I don't understand the length argument. It always comes down to " we are just a manual and a reference, not a book". But then, the script-fu chapter should be two lines: a link to Scheme language reference and "read function comments to learn what they do". I like that the tutorial addresses the object model of GIMP - image/drawable, etc. That's what we need. As to who will incorporate, I don't know.
2012/1/24 Kolbjørn Stuestøl
Kolbjoern
The tutorial is under my spideroak share at: https://spideroak.com/browse/**share/Stephen_Kiel_Pictures/**tutorial The "RoomKey" is tutorial
______________________________**_________________ gimp-docs-list mailing list
gimp-docs-list@gnome.org
http://mail.gnome.org/mailman/**listinfo/gimp-docs-list
Julien Hardelin
2012-01-24 20:49:01 UTC (about 13 years ago)
That's the main problem: who will translate this text to xml? At gimp.org, there are two tutorials about scripts. They were created in 2003. This tutorial could be added there. And we add a link to it in the doc.
Julien
2012-01-25 13:41:20 UTC (about 13 years ago)
Is that really a problem? I can do it.
Julien Hardelin
2012-01-25 18:02:04 UTC (about 13 years ago)
Good!
Will this tutorial be included at the place of the present script-fu tutorial? It is big and I see it as an annex.
Julien Hardelin
