git print dialog doesn't see CUPS printers
git print dialog doesn't see CUPS printers Michael J. Hammel 01 Jan 23:55
  git print dialog doesn't see CUPS printers Robert Krawitz 02 Jan 00:36
   git print dialog doesn't see CUPS printers Michael J. Hammel 02 Jan 22:45
    git print dialog doesn't see CUPS printers Olivier 03 Jan 07:19
Michael J. Hammel
2012-01-01 23:55:39 UTC (almost 14 years ago)
I've got a printer configured under CUPS. GIMP 2.6 installed from yum on F14 sees the printer okay. My custom built GIMP 2.7 does not. I built the print plugin, which doesn't appear to have any CUPS related dependencies that I can see. The print plugin only shows print to file and print to lpr.
Also, I wonder if the 2.6 build is just using the GTK+ print dialog? Seems a little different than the GIMP 2.7 Print plugin.
I've looked through the configure options for GTK+ and GIMP and the only meaningful print option appears to be to disable building the print plugin for GIMP. I don't see anything related to specifically using CUPS.
Is there another library that needs configuration for use with CUPS in order for GIMP's print dialog to see the printer?
FYI: I built Gutenprint's plugin and it sees the printer okay.
Any pointers appreciated. Thanks.
Robert Krawitz
2012-01-02 00:36:56 UTC (almost 14 years ago)
Also, I wonder if the 2.6 build is just using the GTK+ print dialog? Seems a little different than the GIMP 2.7 Print plugin. I've looked through the configure options for GTK+ and GIMP and the only meaningful print option appears to be to disable building the print plugin for GIMP. I don't see anything related to specifically using CUPS.
You may need to install the CUPS development package and rerun configure (remove config.cache first).
Gutenprint uses a hacked-up mechanism based on lpstat or lpc (as appropriate) to query printers. It's ugly, but it works on a wide variety of systems.
Michael J. Hammel
2012-01-02 22:45:14 UTC (almost 14 years ago)
My build script does a "make distclean" before building, which should cover the config.cache. Also, I already have cups-devel installed.
I built 2.7.3 via git but still have the problem. I can't build 2.7.4 or HEAD because of some dependency issues (long story). So I guess it just isn't going to work until I upgrade to F16. Maybe. Or find an F14 RPM of pcre 8.11 (to resolve glib dependencies).
Thanks for the tips, though.
Olivier
2012-01-03 07:19:39 UTC (almost 14 years ago)
2012/1/2 Michael J. Hammel
I have the same problem as you with Ubuntu 11.04, thus maybe it's not
specific to your version of Fedora. Incidentally, to be able to compile the git version, I was forced to delete the system *.la files in /usr/lib and /usr/lib/i386-linux-gnu. This being done, and once the dependencies are compiled in the proper order, I can update my GIMP installation once a week, or more.
Thus maybe we should file a bug about this weird behavior of the Image: File -> Print entry?
Olivier Lecarme
