viewing Dectris X-ray detector data
11 of 11 messages available
viewing Dectris X-ray detector data Halina STANLEY 21 Dec 15:11
  viewing Dectris X-ray detector data Rob Antonishen 22 Dec 13:26
   viewing Dectris X-ray detector data Burnie 22 Dec 20:39
  viewing Dectris X-ray detector data Nicolas Robidoux 22 Dec 20:57
   viewing Dectris X-ray detector data Dov Grobgeld 23 Dec 06:50
   viewing Dectris X-ray detector data stanley@esrf.fr 10 Jan 09:32
    viewing Dectris X-ray detector data Nicolas Robidoux 10 Jan 16:36
viewing Dectris X-ray detector data stanley@esrf.fr 21 Dec 15:14
  viewing Dectris X-ray detector data gg@catking.net 21 Dec 15:39
  viewing Dectris X-ray detector data Mukund Sivaraman 21 Dec 15:40
   viewing Dectris X-ray detector data gg@catking.net 21 Dec 15:48
Halina STANLEY
2011-12-21 15:11:53 UTC (over 13 years ago)
Hi there
I was wondering how easy (?!) it might be to change the GIMP data input/output routines so that instead of reading/writing jpg images "GIMPX" could read/write Dectris X-ray detector format data...
http://www.dectris.com/sites/pilatus1m.html
In fact, we would really only be interested in a very small subset of all the image processing that GIMP can do. For example, certain zones of the 2d detector need to be masked before further data analysis can proceed. The ability to select contiguous regions based on count-rate would be very helpful.
thanks for any replies !
Halina
stanley@esrf.fr
2011-12-21 15:14:46 UTC (over 13 years ago)
Hi there
Halina
gg@catking.net
2011-12-21 15:39:48 UTC (over 13 years ago)
On 12/21/11 16:14, stanley@esrf.fr wrote:
Hi there
Halina _______________________________________________
assuming their "TIF" format is tiff, that should be readable in gimp.
If not maybe you could provide a more specific link to what those data formats actually are.
/gg
Mukund Sivaraman
2011-12-21 15:40:00 UTC (over 13 years ago)
Hi Stanley
On Wed, Dec 21, 2011 at 04:14:46PM +0100, stanley@esrf.fr wrote:
Hi there
Don't fork off a new GIMPX project.
GIMP uses a plug-in system to read/write files. You can easily write support for a new file format by creating a plug-in for it.
Use any existing plug-in's source code as an example: http://git.gnome.org/browse/gimp/tree/plug-ins/common/
Plug-ins for PPM, TGA, RAW (raw data, not camera RAW photos), XPM, etc. are rather simple and can be a good foundation to start a new plug-in.
http://developer.gimp.org/plug-ins.html
If you don't need a GUI, you could also try using GEGL for image processing which will give you more precision. GEGL also supports plug-ins, which are called operations in its nomenclature.
http://git.gnome.org/browse/gegl/tree/operations/external/
http://gegl.org/
Kind regards,
Mukund
gg@catking.net
2011-12-21 15:48:34 UTC (over 13 years ago)
On 12/21/11 16:40, Mukund Sivaraman wrote:
Hi Stanley
Hi there
http://gegl.org/
Kind regards,
Mukund
for repetitive batch processing you could also look at imagemagick which operates from text commands.
If your processing is repetitive this would be a lot more efficient than an interactive interface like gimp.
/gg
Rob Antonishen
2011-12-22 13:26:55 UTC (over 13 years ago)
Halina
A quick look at the link provided indicates that these devices produce 20 bit data:
"Dynamic range 20 bits (1:1,048,576)"
Currently GIMP is limited to 8 bits per channel, so it is not likely capable of dealing with these images at this time.
-Rob A>
Burnie
2011-12-22 20:39:09 UTC (over 13 years ago)
Halina
I also noticed this 20-bit range - however, GIMP processes 24 bits per pixel, eight bits of each red, green, and blue.
The 20-bit outputs of the photon counters could be partitioned into three colored data streams; seems likely that the masking and partitioning of the counter data could be handled by an appropriately designed plug-in.
Just reading a TIFF file with 20-bit resolution grayscale probably would not work, as the data probably would be truncated. But don't give up on current GIMP yet. A TIF front-end in a plug-in that properly partitioned might help.
-Rob A>
gimp-developer-list@gnome.org
Nicolas Robidoux
2011-12-22 20:57:57 UTC (over 13 years ago)
Dear Halina:
Could you please post an example image somewhere?
For example, it would not suprise me if VIPS/NIP2 http://www.vips.ecs.soton.ac.uk/index.php?title=VIPS or ImageMagick http://www.imagemagick.org/ could read it right out of the box.
Dov Grobgeld
2011-12-23 06:50:22 UTC (over 13 years ago)
In the gimp Dicom plugin, I solved this by calculating the minimum and maximum gray levels and then rescaling these to 8-bit. Very primitive, but if someone just wants to paste an MRI-image of their brain into a larger image it is enough.
A more sophisticated approach is my image viewer, giv, that supports various image pixel depths, including floating point and 32 bit images. Giv has a Contrast tool that allows interactively seeing the histogram and choosing part of it to be displayed in the image. Search for Dicom in the giv manual at http://giv.sourceforge.net/giv/giv.html to see an example. Giv allows plugins so if all you are looking for is to view the image, that might be enough.
(If someone (yes, me included) would feel board on a rainy day, I think it would be cool to add the giv contrast tool to the gimp dicom plugin to allow playing around with the gray levels before committing yourself and choosing a certain window for import. This could be a general way of dealing with high-contrast images).
Regards, Dov
On Thu, Dec 22, 2011 at 22:57, Nicolas Robidoux wrote:
Dear Halina:
-- Nicolas Robidoux
Image processing and applied mathematics consultant https://www.ohloh.net/accounts/NicolasRobidoux nicolas.robidoux@gmail.com
stanley@esrf.fr
2012-01-10 09:32:34 UTC (over 13 years ago)
Hi Nicolas
It's really kind of you to follow this up.
I've put an example data set (raw output from the detector) here: https://docs.google.com/open?id=0B_tFwWNVPR8jOGJlNTIwZDYtNjdlYS00N2E2LTlmZjMtZTQ1MWU0YmM1OWFl
which I hope you can open. The file has a header containing various parameters - some to do with data organisation, others experimental... It starts with:
headSize, ByteOrder, DataType, NbCols, NbRows, epoch, sec, mon, I2, I1, intens, photo (this is a photdiode count not a photograph :-)), p1M, p300k, frleon, voltage, current, bpmy, bpmz, byfwhm, bzfwhm, bintens, T_euro
This is followed by the counts in the channels. These data are from a silver behenate sample that gives circular rings around the direct beam (high intensity) position. The part of the detector in the highest intensity area is protected by a rectangular beam stop. There are a couple of wires visible leading away from this area. In these data the direct beam position is off-set from the centre of the detector.
It ought to look pretty....
thanks again ! best wishes
Halina
Quoting Nicolas Robidoux :
Dear Halina:
-- Nicolas Robidoux
Nicolas Robidoux
2012-01-10 16:36:04 UTC (over 13 years ago)
Daer Halina:
This file (Ag_Be_SAXS_0000.edf_orig) is in .edf (European Data Format http://en.wikipedia.org/wiki/European_Data_Format) format?
Adding the "_orig" postfix to the filename would most likely confuse any reasonably all purpose image processing system.
nicolas
