Werror=missing-prototypes
Werror=missing-prototypes Partha Bagchi 18 Dec 17:15
  Werror=missing-prototypes Mukund Sivaraman 18 Dec 17:43
   Werror=missing-prototypes Jernej Simončič 18 Dec 17:49
    Werror=missing-prototypes Partha Bagchi 18 Dec 19:13
     Werror=missing-prototypes Victor Oliveira 18 Dec 22:02
Partha Bagchi
2011-12-18 17:15:37 UTC (over 13 years ago)
Mukund,
You asked to bring missing prototype errors (here?). Anyway, win-snap and common both fail due to Werror-missing-prototypes.
Thanks, Partha
Mukund Sivaraman
2011-12-18 17:43:07 UTC (over 13 years ago)
Hi Partha
On Sun, Dec 18, 2011 at 12:15:37PM -0500, Partha Bagchi wrote:
Mukund,
ender also mentioned win32 build issues. I think he builds now after patching configure.ac to disable this for Windows builds.
Paste the win-snap compile log here.
What fails in plug-ins/common? Is it win32 specific code? Nothing in that dir fails to build on Linux. Paste the compile log for this too.
I can't directly support Windows, but I'll try to help in resolving it.
BTW, -Werror=missing-prototypes was introduced after discussion and I'm not going to remove it. We wasted time with bug reports against the last release on some distros which this compiler flag could've caught. The missing protos simply need to be added. Send the logs and we'll figure out what needs to be done.
Kind regards,
Mukund
Jernej Simončič
2011-12-18 17:49:39 UTC (over 13 years ago)
IIRC, only the jpeg plugin, due to lcms-related issues.
Partha Bagchi
2011-12-18 19:13:39 UTC (over 13 years ago)
2011/12/18 Jernej Simončič :
-- < Jernej Simončič ><><><><>< http://eternallybored.org/ >
There is an exception to all laws.       -- Government's Law
gimp-developer-list@gnome.org
You are probably right. I did a distclean and re compiled and did not see an issue with common - so sorry about that.
As for win-snap, here is what I am getting:
winsnap.c: At top level: winsnap.c:397:1: error: no previous prototype for 'setCaptureType' [-Werror=missing-prototypes]
winsnap.c:642:1: error: no previous prototype for 'InitApplication' [-Werror=missing-prototypes]
winsnap.c:690:1: error: no previous prototype for 'InitInstance' [-Werror=missing-prototypes]
winsnap.c:717:1: error: no previous prototype for 'winsnapWinMain' [-Werror=missing-prototypes]
cc1.exe: some warnings being treated as errors
make[3]: *** [winsnap.o] Error 1 make[3]: Leaving directory
`/usr/src/gimp/gimp-2.7.5/gimp-2.7.5/plug-ins/win-snap' make[2]: *** [all-recursive] Error 1 make[2]: Leaving directory `/usr/src/gimp/gimp-2.7.5/gimp-2.7.5/plug-ins' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/usr/src/gimp/gimp-2.7.5/gimp-2.7.5' make: *** [all] Error 2
Victor Oliveira
2011-12-18 22:02:42 UTC (over 13 years ago)
Hi guys,
I had to make these prototypes in order to build GIMP today, so I've just commited them.
