ANNOUNCE: GIMP 2.7.4 released
ANNOUNCE: GIMP 2.7.4 released Michael Natterer 13 Dec 09:46
Michael Natterer
2011-12-13 09:46:22 UTC (over 13 years ago)
Finally, GIMP 2.7.4 has been released. This is an unstable development version on the way to 2.8, which we hope to release in January. 2.7.4 may, or may not be the last development release before 2.8. Please test it hard to help us find out.
For a complete list of changes since 2.7.3 please see the "Changes" section below. Also see the release notes of the 2.7 series at http://www.gimp.org/release-notes/gimp-2.7.html
Please note that the whole 2.7.x series of versions is considered unstable and is not recommended for use in production even though it might just work for you. Our intention is to make development versions available for passionate users who can provide useful feedback to help us fix bugs and streamline implementation of some of the new features. The upcoming v2.8 also introduces a huge amount of API deprecations and additions that have the potential to break existing 3rd party scripts and plug-ins. Please file bugs for all plug-ins and scripts that do work in v2.6, but don't work in 2.7.4. A migration guide for developers will be provided when v2.8 is out.
Happy GIMPing, --Mitch
Download
GIMP 2.7.4 is available from:
ftp://ftp.gimp.org/pub/gimp/v2.7/
and from the mirrors listed at:
http://www.gimp.org/downloads/#mirrors
The checksum of the tarball is:
bda95a29c3483b8ff458b06b1543f867 gimp-2.7.4.tar.bz2
Changes in GIMP 2.7.4 =====================
UI:
- Add a close button to image tabs in single-window mode - Improve the transform tools' undo strings to be more descriptive - Render the layer's "eye" icon in inconsistent state if the layer is visible, but one of its parents isn't - Add proper stacking for canvas items, so things don't hide each other - Make sure single-window-mode and multi-window-mode are always saved consistently in sessionrc
Core:
- Fix "render_image_tile_fault: assertion `tile[4] != NULL' failed" warnings that occurred for some image sizes - Fix attachment of the floating selection when the gegl projection is enabled
- Replace heal algorithm with a new one by Jean-Yves Couleaud that works much better
- Make resource sub-folders show up in UI as tags, allowing users to easily locate resource collections they may have installed - Fix graphics tablet canvas interaction by moving from gdk_pointer_grab() to gtk_grab_add() for most grabs - Stop using motion hints, they are a concept from the dark ages
Libgimp:
- Add a basic paint dynamics PDB interface
Plug-ins:
- Make writing color space information to BMP files optional - PSD loader now reads and imports working paths
Script-Fu:
- Lots and lots of undeprecations
Developer documentation:
- Add devel-docs/gegl-porting-plan.txt
Source and build system:
- Make git-version.h generation work in shallow git clones - Modernize use of autotools a bit, maintainer-mode and pdbgen are now enabled by default
General:
- Make gimptool install scripts in the correct system-wide directory - Fix lots and lots of stuff found by static code analysis
Contributors ============
Alexandre Prokoudine, Alexia Death, Alexis Wilhelm, Bruce Cowan, Jakub Steiner, Javier Jardón, Jernej Simončič, Karthikeyan S, Kevin Cozens, Martin Nordholts, Massimo Valentini, Michael Natterer, Michael Schumacher, Mikael Magnusson, Mike Melancon, Mukund Sivaraman, Nils Philippsen, Simon Budig, Ville Pätsi
Translators ===========
Albert, Alexandre Prokoudine, Bruno Gurgel, Carles Ferrando, Christian Kirbach, Daniel Mustieles, Dimitris Spingos, Evgenia Petoumenou, Jennie Petoumenou, João S. O. Bueno, Kjartan Maraas, Kolbjørn Stuestøl, Kristjan SCHMIDT, Marco Ciampa, Martin Srebotnjak, Michael Muré, Michael Natterer, Rudolfs Mazurs, YunQiang Su, 神州散人
