Strings freeze for 2.8 is on
7 of 7 messages available
Strings freeze for 2.8 is on Alexandre Prokoudine 03 Dec 23:15
  Strings freeze for 2.8 is on Cristian Secară 04 Dec 22:05
   Strings freeze for 2.8 is on Alexandre Prokoudine 04 Dec 22:43
    Strings freeze for 2.8 is on Alexandre Prokoudine 04 Dec 22:44
   Strings freeze for 2.8 is on Alexandre Prokoudine 05 Dec 14:02
  Strings freeze for 2.8 is on Cristian Secară 10 Feb 21:22
   Strings freeze for 2.8 is on Alexandre Prokoudine 11 Feb 05:06
2011-12-03 23:15:56 UTC (over 13 years ago)
We seem to have fixed the last i18n issues in 2.7, hence strings freeze is on. That means no more changes to user visible messages. Translators should feel safe to catch up on what's changed since the last time they updated the respective PO files.
If you won't be in time with updates for 2.8, this isn't a big deal, because updates can go to 2.8.1 etc.
Cristian Secară
2011-12-04 22:05:56 UTC (over 13 years ago)
In the portable version from Partha site there are several new strings that am not able to find in the .po files. Example:
(File menu)
View Exif...
Save XCF and Export...
Save-As XCF and Export...
(Edit menu)
_Fill with pattern seamless...
(View menu)
Use GEGL
(but this one I remember to be here long ago in English-only) (Image menu)
Separate > [4 other English menus]
(Layer menu)
Li_quid rescale...
(etc.)
What's the mistery ?
Cristi
2011-12-04 22:43:13 UTC (over 13 years ago)
2011/12/5 Cristian Secară :
No mistery. They just ship extra plug-ins.
As for "View > Use GEGL", it wasn't planned to be made user visible in the final release, AFAIK.
2011-12-04 22:44:38 UTC (over 13 years ago)
Oh, and btw both Separate+ and Liquid rescale can be translated (separately). No idea if it works on Windows, though.
2011-12-05 14:02:38 UTC (over 13 years ago)
2011/12/5 Cristian Secară wrote:
(View menu)
Use GEGL
Fixed in Git master, btw. Sorry about that :)
Cristian Secară
2012-02-10 21:22:14 UTC (about 13 years ago)
În data de Sun, 4 Dec 2011 03:15:56 +0400, Alexandre Prokoudine a scris:
It seems that something thawed the freeze, because ~5 trings were changed on the main .po file and ~36n the plugins .po.
Should we expect further changes until 2.8 release ?
Cristi
2012-02-11 05:06:33 UTC (about 13 years ago)
And some changes in po-tags since adding new brushes.
Unfortunately it's possible. I'm not happy about that either, but that's what we have to deal with.
