"Detail in Middle" or "Tile" in Patterns -> Render Map seems to always make something tileable
"Detail in Middle" or "Tile" in Patterns -> Render Map seems to always make something tileable Cristian Secară 02 Dec 10:08
Cristian Secară
2011-12-02 10:08:31 UTC (over 13 years ago)
The Render Map dialog has a dropdown list with Tile and Detail in Middle. Whatever selection I made, the resulting image is always tileable (or I am not able to see any difference).
If the script is ok, then where should the difference be visible ?
GIMP 2.7.4, on Windows Vista 64 bit. I tried also with English interface (start with lang="en") just to make sure some translated name won't screw some parameter, but there was no difference.
Cristi
