babl 0.1.6 fails to build
babl 0.1.6 fails to build Alexandre Prokoudine 20 Nov 02:55
  babl 0.1.6 fails to build Hub Figuière 20 Nov 03:03
   babl 0.1.6 fails to build Victor Oliveira 20 Nov 17:23
  babl 0.1.6 fails to build Øyvind Kolås 20 Nov 16:19
   babl 0.1.6 fails to build Alexandre Prokoudine 20 Nov 17:47
2011-11-20 02:55:12 UTC (over 13 years ago)
babl 0.1.6 9as well as Git master) fails to build on Ubuntu 11.10: http://pastebin.com/9x5e8PsG
I'd file it to bugzilla, but apparently there is no babl component.
Hub Figuière
2011-11-20 03:03:14 UTC (over 13 years ago)
There is a babl component in GEGL product.
Cheers,
Hub
Øyvind Kolås
2011-11-20 16:19:29 UTC (over 13 years ago)
It will probably build if you pass --disable-introspection but really I would hope that the distros had started picking up and made sure that these things worked properly by now.
/pippin
Victor Oliveira
2011-11-20 17:23:36 UTC (over 13 years ago)
Strange. I've been able to compile the latest babl in Ubuntu 11.10. I had to because Gegl needs 0.1.6 now.
I just used "./autogen.sh ; ./configure ; make".
Cheers,
Hub _______________________________________________ gegl-developer-list mailing list
gegl-developer-list@gnome.org
http://mail.gnome.org/mailman/listinfo/gegl-developer-list
2011-11-20 17:47:40 UTC (over 13 years ago)
On Sun, Nov 20, 2011 at 8:19 PM,
