Crucible test results for gegl and babl
Crucible test results for gegl and babl Bryce Harrington 06 Sep 04:51
Bryce Harrington
2006-09-06 04:51:47 UTC (over 18 years ago)
On the Cairo IRC channel I offered to Pippin to also run gegl in our Crucible test environment at OSDL. Today we managed to get this set up and running, and here are the first set of results:
babl: http://crucible.osdl.org/runs/1806/ babl: http://crucible.osdl.org/runs/1807/
gegl: http://crucible.osdl.org/runs/1805/ gegl: http://crucible.osdl.org/runs/1808/
The build results are in the logs/ subdir. There was a build issue for babl on amd01 you might want to look at. The error on nfs12 appears to have been due to not having ruby installed on the system; I'll install it.
Run 1805 isn't valid because it ran before the necessary babl piece was downloaded, so ignore it.
Run 1808 is valid, but is showing some missing dependencies, which I'll take a look at later.
Bryce
