RFE: predefined (and customizable) list of aspect ratio values in Crop tool options
14 of 14 messages available
RFE: predefined (and customizable) list of aspect ratio values in Crop tool options wwp 27 Oct 11:44
  RFE: predefined (and customizable) list of aspect ratio values in Crop tool options Alexandre Prokoudine 27 Oct 12:11
   RFE: predefined (and customizable) list of aspect ratio values in Crop tool options wwp 27 Oct 12:24
    RFE: predefined (and customizable) list of aspect ratio values in Crop tool options Michael Natterer 27 Oct 12:28
     RFE: predefined (and customizable) list of aspect ratio values in Crop tool options wwp 27 Oct 12:41
      RFE: predefined (and customizable) list of aspect ratio values in Crop tool options Alexia Death 27 Oct 12:54
       RFE: predefined (and customizable) list of aspect ratio values in Crop tool options wwp 27 Oct 13:00
        RFE: predefined (and customizable) list of aspect ratio values in Crop tool options Akkana Peck 28 Oct 20:17
       RFE: predefined (and customizable) list of aspect ratio values in Crop tool options Olivier 27 Oct 14:23
        RFE: predefined (and customizable) list of aspect ratio values in Crop tool options Alexandre Prokoudine 27 Oct 14:31
         RFE: predefined (and customizable) list of aspect ratio values in Crop tool options Olivier 27 Oct 14:42
          RFE: predefined (and customizable) list of aspect ratio values in Crop tool options Alexandre Prokoudine 27 Oct 14:50
          RFE: predefined (and customizable) list of aspect ratio values in Crop tool options Alexia Death 27 Oct 15:15
RFE: predefined (and customizable) list of aspect ratio values in Crop tool options Alexandre Prokoudine 27 Oct 15:49
wwp
2011-10-27 11:44:46 UTC (over 13 years ago)
Hello there,
using Gimp 2.6, I always use the Fixed aspect ratio thing to crop photos. I always have to manually edit the ratio value in the widget right below, to get 1:1, 3:2, 4:3, etc. (there are many common aspect rations that fit photo printing, see reference below).
Wouldn't it be nice, as a tiny minor usability enhancement, to get a combo list there for common values. Customizable if possible.
This enhancement may apply to other simlar widgets in the GUI (Rectangle/Ellipse select - I couldn't find any other one).
http://en.wikipedia.org/wiki/Aspect_ratio_%28image%29
wwp
2011-10-27 12:11:25 UTC (over 13 years ago)
On Thu, Oct 27, 2011 at 3:44 PM, wwp wrote:
Hello there,
GIMP already memorizes values that you used before. So when you start typing in, it tries to autocomplete.
wwp
2011-10-27 12:24:27 UTC (over 13 years ago)
Hello Alexandre,
Hello there,
Oh, you're right, type-ahead does auto-complete.. but it doesn't remember values across when I restart the application.
Anyway keeping a trace of all that is typed is not always good idea. It would remember typos and mistakes too. I could live with it, if the remembered values are stored (even if I have to purge the list manually by editing a config file).
That type-ahead concept is also is different from a combo list (no need for keystrokes to reuse a predefined value), and you can even get both.
wwp
Michael Natterer
2011-10-27 12:28:35 UTC (over 13 years ago)
On Thu, 2011-10-27 at 14:24 +0200, wwp wrote:
Hello Alexandre,
Hello there,
See https://bugzilla.gnome.org/show_bug.cgi?id=156858
Regards, --Mitch
wwp
2011-10-27 12:41:56 UTC (over 13 years ago)
Hello Michael,
Hello Alexandre,
Hello there,
Right. The request is from 2004 and not being commented for almost 3 years. I thought it was more or less either forgotten or not taken care of.
This present thread leads leads me to second #156858 AND to request for the type-ahead memory to be persistent - if I well understand it's reset when I restart the app.
Worth to post a comment to #156858 and submit a new query for the type-ahead memory in your opinion?
wwp
Alexia Death
2011-10-27 12:54:27 UTC (over 13 years ago)
Hi all,
2.7 has brand new sparkling tool presets that fill this need :) They have been widely used exactly for this purpose by early testers.
Best, Alexia
wwp
2011-10-27 13:00:56 UTC (over 13 years ago)
Hello Alexia,
On Thu, 27 Oct 2011 15:54:27 +0300 Alexia Death wrote:
Hi all,
Interesting! I'll give 2.7 a try and come back later if necessary.
Unsubscribing now, thanks to all!
wwp
Olivier
2011-10-27 14:23:33 UTC (over 13 years ago)
2011/10/27 Alexia Death
Hi all,
I don't understand how that can be used for saving the fixed aspect ratio for the crop tool. The only saved options see to deal with other tools?
2011-10-27 14:31:57 UTC (over 13 years ago)
It can be used for that quite literally :) Just try it :)
Olivier
2011-10-27 14:42:13 UTC (over 13 years ago)
2011/10/27 Alexandre Prokoudine
With your encouragements I tried further. I have the impression that in
order to use a specific tool preset, first I must choose a tool different from the one I'm using, otherwise selecting the tool preset I need has no effect. Is there something hidden that I don't understand?
In other words, I want to use the Crop tool with a specific set of options I saved before, and which by the way does not deal with the options that are shown in the Tool Preset Editor (none of them). If the Crop tool is currently selected, I must first select another tool, then select the tool preset I saved before.
Am I missing something obvious?
2011-10-27 14:50:51 UTC (over 13 years ago)
for the crop tool.
With your encouragements I tried further. I have the impression that in order to use a specific tool preset, first I must choose a tool different from the one I'm using, otherwise selecting the tool preset I need has no effect. Is there something hidden that I don't understand?
This is definitely not the case for me. Switching between 16:9 and 3:2 tool presets works like a charm here. Tools are also automatically switch, otherwise what's the point of presets in the first place? :)
Are we still talking about presets you can create and load from Windows/Dockable Dialogs/Tool presets?
Alexia Death
2011-10-27 15:15:59 UTC (over 13 years ago)
If you have the pereset you want to apply currently active you need to switch to a different preset for a moment. Its a minor annoyance that needs a fix. But tool gets changed automatically to the one in preset. If you have only one preset you will need to have one other to swap to...
Tool preset editor lets you control what aspects of the preset get applied, not the preset itself. Creating and updating the preset is perhaps clearer if done in the tool options menu.
2011-10-27 15:49:02 UTC (over 13 years ago)
Yes we are. I pursued my tests, and I observed that if I there is only one tool preset for a given tool, selecting that one when the tool is already selected does not change anything.
Ah, that is a correct observation.
P.S. I'm ataking this back to the list as you replied personally. I'm assuming that you didn't mean it :)
Akkana Peck
2011-10-28 20:17:16 UTC (over 13 years ago)
wwp writes:
You don't have to use 2.7 to get tool presets. I use tool presets all the time in 2.6 for crop and rect select aspect ratios. http://www.shallowsky.com/blog/gimp/gimp-tool-presets.html
...Akkana
