More Brush dynamics?
8 of 8 messages available
More Brush dynamics? Richard Gitschlag 13 Sep 18:26
  More Brush dynamics? Alexandre Prokoudine 13 Sep 22:42
   More Brush dynamics? Richard Gitschlag 14 Sep 13:52
    More Brush dynamics? Alexia Death 14 Sep 16:32
     More Brush dynamics? Richard Gitschlag 15 Sep 03:05
      More Brush dynamics? Brian Vanderburg II 15 Sep 13:37
       More Brush dynamics? Richard Gitschlag 15 Sep 13:50
        More Brush dynamics? Brian Vanderburg II 15 Sep 13:54
Richard Gitschlag
2011-09-13 18:26:41 UTC (about 14 years ago)
I recently discovered I've misplaced my Wacom pen stylus -- the tablet equivalent of losing your car keys. Ouch.
Anyway, it gave me an idea for GIMP: Can the "Incremental" and "Fade Out" brush options be incorporated into the Brush Dynamics grid? The options basically link opacity to stroke length, but it would be nice if we could link stroke length with other factors like brush hardness or color. (For example, linking color to stroke length would mimic the effect of a simple gradient.)
2011-09-13 22:42:14 UTC (about 14 years ago)
Richard Gitschlag
2011-09-14 13:52:40 UTC (about 14 years ago)
Date: Wed, 14 Sep 2011 02:42:14 +0400 From: alexandre.prokoudine@gmail.com To: gimp-developer@lists.xcf.berkeley.edu Subject: Re: [Gimp-developer] More Brush dynamics?
Dunno about "Increment", but "Fade" is already in the brush dynamics matrix for 2.8. The matrix is currently 7x10, and I strongly suggest the team to consider building and selling a customized version of monome to control it :)
Actually I'm probably mistaken on the "incremental" option -- been a long time since I tried to use it.
So what are all the dynamics on the plate for 2.8 anyway (compared to 2.6) ?
Alexia Death
2011-09-14 16:32:47 UTC (about 14 years ago)
Why not grab some 2.7.3 build and try it out? :) There is lots to discover:)
Richard Gitschlag
2011-09-15 03:05:31 UTC (about 14 years ago)
Date: Wed, 14 Sep 2011 19:32:47 +0300
Why not grab some 2.7.3 build and try it out? :) There is lots to discover:) --
--Alexia
*shrugs* preference for stable versions maybe? The only "non-stable" FOSS I run is FontForge and that is by necessity, not choice.
Brian Vanderburg II
2011-09-15 13:37:05 UTC (about 14 years ago)
I've played with 2.7.3 on Windows a little bit. Here are some other ideas for new dynamic outputs: Hue, Saturation, and Value/Luminance
Brian Allen Vanderburg II
Richard Gitschlag
2011-09-15 13:50:19 UTC (about 14 years ago)
Date: Thu, 15 Sep 2011 09:37:05 -0400 From: brianvanderburg2@aim.com
To: gimp-developer@lists.XCF.Berkeley.EDU Subject: Re: [Gimp-developer] More Brush dynamics?
Those can already be simulated using the Color dynamic and careful RGB values, although as mentioned in bug #572300 the current "Color" dynamic (i.e. low pressure = FG, high pressure = BG) is a bit counter-intuitive in 2.6.
Gimp-developer mailing list
Brian Vanderburg II
2011-09-15 13:54:48 UTC (about 14 years ago)
If I want something more complicated, say I want to use the color output and fade input to paint a gradient stroke, but also want the pressure to adjust the saturation, so lighter pressure would make the stroke more gray and harder pressure would make the stroke more color. How would I do this with the current dynamic?
